Bosch wvti2840 The machine does't dry. The drying program runs till the end but in the end the clothes stays wet and cold.
FitzOriginal
  • 842 Answers
SOURCE: Servis Washing machine clothes wet
I don't know the specific machine, but this is a fairly generic problem, so I hope the following helps: The empty pump cycle is a timed operation, the fact that there is still water in the drum after the time allowed for the pump to drain it has run out means that the water isn't clearing out fast enough.
In order of probability, the problem is usually caused by:
1. A blocked filter
2. An obstruction in the empty pipe or drain
3. A Faulty pump
1 Blocked Filter: Many machines have a small door in the bottom of the chassis. Behind this door (Usually about 5 inches square) is a filter, which will usually unscrew. In this filter you will find fluff, string, coins, the odd small sock and all sorts of nasty stuff if you haven't had the filter out before. If the filter is blocked then the pump is having to draw water through all that gunk and it will run out of time and leave water in the drum. Clean the filter in the sink, pocket the coins you find and make a note to clean it regularly in the future Most manufactures will suggest you check it every 2 months or so, depends how often you are using the machine of course.
Unfortunately, other machines do not have filters so easily accessible. If there is no door or obvious access to the filter, some manufacturers put a trap in the rubber hose that feeds the pump. The pain here is that the access to these traps is gained by dragging the bachine out of its place under the work surface and tipping it on to its back. Track the waste pipe back to locate the pump. On the other side of the pump will be a thicker (usually black rubber) pipe and built into this pipe is usually a little bucket that stuff can fall into before it gets to the pump. You can usually squeeze the pipe and feel if there is stuff in it. If there is, then depending on the machine again, some of these traps will have a plug in the bottom that is held in place by a spring clip (Pliers to compress the spring to get it off) or a screw clip (Unscrew with a screwdriver). Enev if there is no trap as such, squeeze the rubber delivery pipe and feel for obstructions (Often a sock!), if necessary, disconnect the pipe from the pump to gain access to the blockage. WARNING!: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, to the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend butting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
2. An obstruction in the empty pipe or drain: Start at the point that the pipe enters the household drain pipe, pull out the empty pipe and check that water will flow freely into the drain (Stuffing the garden hose down there and turning it on (but not TOO FAST) will usually demonstrate if there is a blockage. If this is free, check the pipe that runs from the pump to the drain (This will need the machine tipping as described above, and possibly the pipe removing from the pump to check it.
3. A Faulty Pump:If you have done everything described so far, then you have checked for obstructions in the pipe leading to the pump, the pipe leading away and you have cleaned out any filters or traps... If you still have a problem, you have a faulty pump. This is highly unlikely. These pumps have induction motors (no brushes to fail) and in my experience, they either work, or they don't. They very seldom "work a bit". If SOME water is being pumped (check by putting the empty hose in the sink and watching) then you really need to double check your work before replacing the pump. Good news is, if you do have to they are usually reasonably priced.
Posted on Feb 09, 2009
  • 41 Answers
SOURCE: hoover 600mb doesn't spin
Valve blocked in rear of drum. Switch off power supply before cleaning. If the problem still occurs it could possibly be the brushes in the motor. both jobs are simple and very cheap to repair
Posted on Sep 03, 2009
dmftrucker
  • 1922 Answers
SOURCE: the clothes are very wet at the end of the cycle.
is your "anti-siphoning" valve or pump plugged with lint, etc. debris from previous laundering, also if it dries them sufficiently the 2nd time this is where I would start trouble-shooting the washer
Posted on Oct 29, 2009
Testimonial: "This answer wasdead on correct.Here is a heads up for owners of this machine.DO NOTuse Purex 3-1 sheets.I found three of these sheets inside the valve"
  • 714 Answers
SOURCE: My washing machine does not spin dry the clothes
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve
Posted on Jan 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: The washer is not spinning
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
I just had the LG WM3987HW washer/dryer combo installed on Saturday, and it will not dry our clothes. This machine is ventless and dries by dehumidification. The clothes are more dry at the end of the spin...
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Nov 29, 2010 | LG WM3987HW Front Load Washer / Dryer
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
My Bosch Classixx washer dryer has stopped drying and the clothes come out steaming hot and steam escapes from the powder drawer during the drying cycle. I have had an engineer out and he says the airflow...
if you have a very large load of clothes in the machine on the dry cycle, what tends to happen is that the clothes are not flapping around in the drum loosely but they are going around the drum in a big mass, with the result that they just get very very hot and steam will escape out the soapbox draw. When this happens, heater unit that becomes overheated ant the thermostats will eventualy cut out resulting in cold air being circulated instead of hot. You will need to have them replaced again. when replaced, put on a drycycle with only a few garments in the machine and you will see a big difference in it perfomance. washer/dryers are not very effective on the drying cycles with a full washload.
if you need any more help, you may email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Bosch Classixx WVF 2402 Front Load...
Clothes still wet aftre drying cycle over
It sounds as if the wash cycle isn't terminated by pumping the rinse water out and spinning to rid the clothing of most of the water.
Most dryers sense moisture but I think they all will have a maximum run-time to prevent possible fires if the programmer fails to shut them down at the end of the drying cycle.
I would watch the machine and when it started the drying cycle, I would shut it off and check for surplus water that hadn't been pumped out as it should have been.
Feb 03, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch WET 2820 dryer pumps in water
most likely a electrical fault have programmer checked
Jan 11, 2009 | Bosch Logixx WFT 2806 Front Load...
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Tumble dryer not working
I managed to solve the problem the following way: I noticed that if you unplug the Sensor-NTC(part nimber 154431 https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WET2820GB%2f13 ) that controls temperature of air in the air channel, the drying cycle runs as you describe above. So this circute was checked up to the power module. Contacts of the Sensors plug were tightened; I think this solved the problem; resistance of the sensor checked. It must be 4.8K at 25 degree C. and decrease when temperature increases. I dipped the sensor in a glass with hot water.
Oct 25, 2007 | Bosch WET 2820 Front Load Washer / Dryer
Drying cycle - laundry comes out wet!
possibly that drain pump is not pumping out - washer dryers take in water during the dry cycle. check filter
Mar 17, 2007 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
