Question about Troy-Bilt 179cc 24" Snow Thrower Storm 2410 Electric Start
Snow thrower starts then shuts down after a few minutes
Moved choke adjustment knob to the non choke position, no help. fresh regular gas used.
    Genius:
  • 1,406 Answers
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Posted on Jul 28, 2014
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Stalling
drain gas from carb and tank get some fresh non ethynol gas
while carb bowl is off spray/ clean with carb cleaner spray.
when you drain gas put it in clear container so you can see if there was water or dirt in it. helps to figure out the problem
Mar 27, 2014 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
Yard machine snow thrower
Try a squirt of starting fluid into the carb.If it does not fire then it is time to replace the points and condensor.
Dec 15, 2013 | Garden
I have a Craftsman 22" Auger type snow thrower with electric start thatwill not start. It had gas in it from last winter. I primed it , I set the choke to full, gas open all the way and, at first, it
if you are using ethanol the check the gas lines for a plug because the ethanol leaves a residue behind that can plug your gas line.
Dec 29, 2012 | Garden
Engine surging 179cc craftsman snow thrower
sounds like the carb will need removing and having it ultrasonic cleaned
Dec 16, 2011 | Mtd Garden
I used the snow thrower the first time this year (model PP1150E27, bought in 2009 only used it the first time now), I saw blue flame came out from the muffler. When I tried to use it in the afternoon, the...
I have a Poulan Chain Saw as well. If you modle has a choke, you must have it on to start it. Once it warms up, move the choke half off and then full run position. You may also need to ensure you have a fresh fuel/oil mixture for optimum performance and to prevent frying the motor. Good luck...
Feb 06, 2011 | Poulan Garden
!332 Snow Thrower will not Start - At full choke
change gas filter and spark plug
Oct 07, 2009 | Garden
Snow thrower won't start.
could possibly be the governor it may have contacted the flywheel if it has came apart under the flywheel cover  are the metal fragments easy to pick up with a magnet or  are the aluminum ?  if they are not picked up by a magnet  your problem lies  else wear
Feb 16, 2009 | 2004 Yamaha YZ 450 F
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Troy-Bilt 179cc 24" Snow Thrower Storm 2410 Electric Start Logo
204 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
