Microtek inverter showing fuse blown - Computers & Internet
3 Suggested Answers
protek480
  • 1714 Answers
SOURCE: MICROTEK INVERTER HELP
Bad batteries, replace all of them together.
Posted on Oct 03, 2009
dontbother10
  • 2220 Answers
SOURCE: my microtek inverter 800va is showing fuse below
No reply.
Posted on Feb 18, 2010
Microtek Inverter high output problem
Did you check the voltage under load, some power supplies float high when there is no load connected
Mar 01, 2014 | Electronics - Others
Hi, I have Microtek 810 Inverter, it is charging properly, problem starts when mains goes off and inverter is in Battery mode, then output of inverter shows no voltage, even i conected multimeter to...
Good day!
You have to do is:
Check the battery if it is leak.Use a voltmeter to test the output voltage of the battery.If your battery had a low supply voltage even you charge it for 3 hours and above.Replace the battery immediately.
Thank you and good luck.
Apr 21, 2011 | Vacuums
I am using microtek 810. Inverter section is ok. In the pcb there are two 40amp fuse which were blown off. suspected heavy current drainage. both fuses are in parallel and in the battery -ve line. i...
If this is a 12 volt battery situation, 24.6 volts is not doing good things for your batteries--it will buckle the inner plates causing immediate battery failure. Were the fuses themselves blown or just the fuse mounts which may have been underrated. You definitely need a schematic for this system--try googling 'microtek 810'. Good luck!
Aug 15, 2010 | Garden
I have a Microtek 17 in monitor and recently it has started to flicker badly when switch on after a couple of minutes it settles down to normal. Can you offer any comments re fixing this problem? Many...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 05, 2010 | Microtek 710S 17" Flat Panel LCD Monitor
I have a microtek 710s monitor, that powers on but
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | Computers & Internet
My microtek flat screen monitor goes black every 5 seconds and must turn it off and back on and it repeats the same thing.
I assume that you have already try it on another PC with the same result.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Apr 03, 2010 | Microtek C593 15" Flat Panel LCD Monitor
Oct 02, 2009 | Electronics - Others
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
