Question about Precor Exercise & Fitness
Precor 966i dead has no power - Precor Exercise & Fitness
2 Suggested Answers
outfield502
  • 79 Answers
SOURCE: where can I purchase a
review on gympart.com
Posted on Sep 07, 2010
We only get a STOP KEY and it will not run
c966 have Precor transported from one place to another place is not rash to give any signal in transcri could you help
Dec 16, 2015 | Precor C966i Treadmill C 966i
PRECOR C956 power switch wont stay on
The power switch on Precor treads is also a circuit breaker. If it trips when plugged in, you have a dead short in the machine.
Feb 06, 2014 | Precor Exercise & Fitness
What is error 28
Precor Error 28, Temperature Too High Probable Cause 1. The lower PCA cooling fan is clogged.
2. The lower PCA cooling fan is inoperative.
3. The running belt and/or deck are badly worn.
4. The lower PCA is bad.
5. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Inspect the fan mounted on the lower PCA for dust/debris buildup. Clean if necessary, ensuring the fan spins freely. Some lower PCA's do not have a cooling fan and others may have the fan mounted on the underside of the lower PCA making it not as visible.
  2. The fan was free of dust or debris but does not spin. Make sure that the fan wiring is secure and properly connected to the lower PCA. If no obstruction to the fan and the wiring is good but fan still doesn't turn, replace the lower PCA.
  3. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions; compare the values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  4. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  5. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 28
Sep 13, 2013 | Precor C966i Treadmill C 966i
Precor error 15 input voltage
Precor Error 15, AC Input Voltage Too High Probable Cause 1. AC input voltage is incorrect.
2. AC input voltage transients. Transients can be caused by lightning strikes or by other pieces of equipment sharing the unit's AC power.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. Ensure the AC grounding for the unit's outlet is good and verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error Code 15
May 18, 2013 | Precor C966i Treadmill C 966i
Error 32
LUBE OR wax you deck belt, this happen for autoprotection electronic system. To due a lack of LUBE maintenance schedule.Do it right now according with owner manual.
2)lube THE rollers bearings too use WD-40 for the bearings only
3) Test the drive belt motor, for cracking or worn belt, replace or adjust in according.
4) Test the motor voltage input, if there are the motor need repair, see my personal TIPS for troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 16, 2012 | Precor C966i Treadmill C 966i
Precor 9.25i treadmill will not turn on at on/off switch. It throws a spark then immediatly turns off
With a few more details I am sure we will be able to work through is issue together and get you back into your exercise program shortly. If you would please give us a call at 1-800-347-4404, one of our technicians will be more than happy to assist you. Please give us a call at 1-800-347-4404 Mon-Fri 6AM-5PM, except Thur 6AM to 3PM, Pacific time.
- Precor Customer Support Team
Feb 28, 2012 | Precor C966i Treadmill C 966i
Buttons stuck
Dear Sir:
I will help you , inmediately.
This problem is normally by the use. Go to radio Schak , and buy some Spray for to clean and lubricate electronic parts, contacts, buttons , or Spray for clean to pressure.
This will be fix it this problem.
Thank you in advance,sincerely. God bless you.
If you need further assistance please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 12, 2011 | Precor C966i Treadmill C 966i
Motor runs but when load is put on treadmill motor slows down substantially. Repairman tech said motor was bad. Took motor to two electric motor repair shops and they tested it (not under load) and stated...
Excessive wear on the deck and belt can cause high friction which then puts a heavier load on the motor. You may want to check the belt and deck for wear.
Jul 29, 2011 | Precor 966i 966i Treadmill...
The belt on my Precor C966i treadmill is not running and the display is flashing an "Error 22" message - what's the problem?
Error 22 means the drive motor is diconnected. you will hear the fan and other parts make noise but check the red and black anderson connection between the main circuit board and motor.
Dec 24, 2010 | Precor C966i Treadmill C 966i
Exercise & Fitness Logo
43 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
