Question about Panasonic PT-65WX51 65" Rear Projection Television
Very dark picture
We have a model PT-65WX51E with avery dark picture and visual controls wont allow it to become bright enough to watch anything except shows and movies with a daytime theme
SOURCE: PICTURE DARK
Where is the chip located? Where is the disc capacitor? I have no service manual is there picture of parts somewhere to locate these?
Posted on Apr 05, 2006
techman
  • 3130 Answers
SOURCE: brightness
Yes there is, you can very carefully take off the back of front speaker grill and the wood cover behind this. There you will see several controls I think six total, three on the top and three right below it, you want to turn up whats called the three screen controls for the red blue and green but you will need a B & W picture on the TV so you can balance the greay scale. if you do not balance the grey scale the TV will not look good. if you do not think you can do this adjustment properly, please play it safe and call in a tech to do these adjustment for you. Good Luck
Posted on Mar 23, 2007
SOURCE: dark picture
@ 6 years old I'd be willing to bet that it's time to replace the lamp. They lose brightness over time so that could be what the problem is.
Posted on Jan 02, 2008
  • 280 Answers
SOURCE: Panasonic PT-61G63W Too much Black Serial No: MY83430025
The mirror should also be cleaned. but there is more adjustments that can bring up brightnes ie G2 on the flyback transformers but that is some thing a tech should do. Because you have to ad enough of each color to get a gray scale. if you are off the picture will be tinted and your color will be way off.
Posted on Jun 20, 2008
spqr163
  • 37 Answers
SOURCE: Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Posted on Mar 12, 2009
Screen is really bright on dynex dx-l42-10a. Still show picture but bright no matter how it is adjusted. Was fine while watch TV & picture just got bright like the darkness quite. Any suggestions & what...
Sounds like screen voltage has exceeded much. Its LOT adjustments should be checked. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 25, 2014 | Televison & Video
Chage bulb tv is still dark
The wrong or faulty lamp may cause darkness
Apr 21, 2009 | Panasonic PT-52LCX66 Projection Television
Poor dark picture on some movie stations
check cable box for input, whether it is 480, 720, 780, 1080.
Dec 08, 2008 | Panasonic PT-60LCX64 Television
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Dec 26, 2007 | Panasonic PT-61G54 61" Rear Projection...
PT-65wx51e 65in
suddenly breaks pink & green colors in bottom left & top right corners with distortion in picture
Dec 09, 2007 | Panasonic PT-65WX51 65" Rear Projection...
Rear projection dark picture
Open up the front of the set and find the screen controls and perform a grey scal alighnment by adjusting the red , blue , and green screen controls but be carefull and make sure you adjust them evenly or the picture will not look right. Good Luck
Mar 23, 2007 | JVC AV-56WP30 56" Rear Projection...
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
Dark picture
I think you have a regulation problem and all the voltage supplies are lower than what they should be,the fact that the picture gets distorted is one thing it lead me to believe that is the problem.This can be caused by a loose conection in the power supply ,I would suggest not to use it until it gets repaired or it might become worst and more expensive.Be careful if you remove the back and try to repair it yourself.
Oct 02, 2006 | Panasonic PT-61G54 61" Rear Projection...
Panasonic PT-65WX51 65" Rear Projection Television Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
