Question about Asrock P4V88 (P4V88 RAID) Motherboard
Asrock p4v88 9 beeps
Post 9 beeps at boot
    Brigadier General:
  • Asrock Master
  • 3,400 Answers
Http://pcsupport.about.com/od/fixtheproblem/tp/ami-beep-codes.htm
THE MOTHERBOARD HAVE GIVEN YOU THE CODE OF
CHECKSUM ERROR.TRY CLEAR CMOS IF THAT NOT HELP
THE MOTHER IS IMPOSSIBLE TO FIX.
Posted on Feb 16, 2014
Motherboard starts but no signal in the monitor
Hello here is the cpu list:
http://www.asrock.com/mb/Intel/P4i45G/?cat=CPU
Other cpu`s than them on the list, does not fit the mainboard.
This will cause the mainboard not to boot up, when the cpu is wrong.
The (wrong) cpu will fit the socket, but it does not fit the cache size, fsb, and so on.
Look also in the manual:
http://www.asrock.com/mb/Intel/P4i45G/?cat=Manual
The problem could also be the power supply failing, try to change that.
Did it boot up before you changed the cpu ???
Any beep codes ??
Look also at this page:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Good luck
Feb 17, 2013 | Asrock P4I45G Motherboard
I have a m,b, asrock 845 presscot mothwer board cpu fan is running but not booting and not display .
are you getting any beeps. These can tell you what your problem is. Just google asrock beep codes
Aug 25, 2010 | Asrock 845GV (P4I45GV) Motherboard
One long 8 short no boot
This is telling you that your video card has a problem. If it's an "add on" card, remove it and re-seat it. Otherwise, go get yourself another video card.
Jun 24, 2010 | Asrock P55 Deluxe (4711140875910)...
3 beeps when i boot my pc with ram but no beeps when i boot without ram
Here is the info I found on the Asrock website. This would be a normal code if you have no RAM in the system.
Beep Code Descriptions 1 short Memory refresh timer error. 2 short Parity error. 3 short Main memory read / write test error. 4 short System timer failure. 5 short Process error. 6 short Keyboard controller BAT test error. 7 short General exception error. 8 short Display memory error. 9 short ROM BIOS checksum error. 10 short CMOS shutdown Read/Write error. 11 short Cache Memory bad.
Apr 14, 2010 | Asrock K7S41GX Motherboard
Have Comp. w/Asrock MOBO.It's been sitting
For that open cpu cabinet
Reattach the RAM memory.
Open processor fan and processor reattach both.
Make sure motherboard circuit could not ground with cabinet.
Pull cmos cell from motherboard for 10 minutes .
Remove pci cards from motherboard if any.
Reattach VGA card if installed.
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 13, 2010 | Computers & Internet
No boot and beeps
The exact fault code indicates RAM or a problem accessing the RAM.
Check that you are using recommended/Approved RAM as ASUS and ASROCK (the budget arm of ASUS) are notoriously fussy with RAM.
If it all checks out then your northbridge could be dead and it will probably be scrap.
Feb 21, 2009 | Asrock K7S8XE Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
On POST Computer Beeps
Put your memmory freq lower in the bios settings they are set to high for your type of memmory thats why it beeps or does not show boot post screen.
Oct 17, 2008 | Asrock 939Dual-SATA2 Motherboard
No beeps on boot up with asrock mobo? help plz
While booting BOIS goes for POST check for detecting the all the hardware .
Disconnect all the connection to DVD, HDD, FDD from MOBO.
Rmove all RAM and start the ssytem from testing RAM Serviceability. If you listened a long intermittent beep place a single pices of RAM in MOBO ( repeat test with other RAM also).
Other wise your video card is unserviceable, if you have any addon plugins like NVIDA graphics card you can check
Jun 10, 2008 | Asrock K7S8X-R3 Motherboard
Error signal ASRock P4VM800
When you open to you're bios menu, either at the top or at the bottom of the screen will be a name of you'e bios. In you're case the name is at the bottom of your bios menu. (American Megatrends Inc.). Or for short AMI You could search google for, AMI bios beep codes.
And you can click on this link, which shows what AMI say's about 3 beeps.
http://www.bioscentral.com/beepcodes/amibeep.htm
You need to test you're memory. (Only if cleaning the memory has did not change the beep error beeps).
First remove you're memory & blow out the DIMM slots with canned air. Clean the copper on the memory with house hold alcohol on a lightly dampend cotton swab. (Let it dry), (Do not touch the copper with you're fingers. Re-install you're memory.
If you have more than one DIMM. Remove the bank farthest from the CPU & boot the PC. Did you hear the 3 beeps? Remove the the next bank & re-install the one you removed first in to the slot closest to the CPU. Boot the PC, again did you hear the 3 beeps?
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Apr 27, 2008 | Asrock P4VM800 Socket478/SAT/A&V&L/Modem...
Asrock P4V88 (P4V88 RAID) Motherboard Logo
114 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
