Question about Harman JBL Pulse
Bluetooth passkey Lost my the box that the product came with along with manual, so I don't know the bluetooth passkey when hooking up to a computer?
Trying to connect jabra BT2080 to phone. says enter passkey?
  1. Bluetooth device A looks for other Bluetooth devices in the area
  2. In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection.
    You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves.
  3. Bluetooth device A finds Bluetooth device B
    Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed.
  4. Bluetooth Device A prompts you to enter a password (PassKey)
    With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices.
    On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
  5. Bluetooth device A sends the Passkey to Bluetooth device B
Jan 26, 2011 | Jabra BT2080 Bluetooth Headset
I do not know what my passkey is. My bluetooth's idea is BCE-OTE1, and I lost my manual. How can I find my passkey?
If your referring to Bluetooth Passkey, most devices ave a default for 1234 or 0000. Maybe try one of those, if not, post a few more specifics.
hope this helps,
R
Nov 07, 2010 | Cell Phones
How can i turn on the bluetooth in my laptop
Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instruction.
Hope this helps. Bud
Jan 21, 2009 | Computers & Internet
Install bluetooth
Normal 0 Go to Control Panel and click on Sound.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
Click NEXT.
Finish and follow any on screen instructiond.
Jan 11, 2009 | Logitech MX5000L
Can't find my Motorola H681 numeric passkey for connecting it
The default is usually 0000 on most bluetooth headsets, try to find the manual for your bluetooth device, it should say.
Jan 08, 2009 | AT&T Blackberry Curve 8300 Smartphone
Printer not working - unknown error message
Click NEXT.
Jan 03, 2009 | Office Equipment & Supplies
Passkey
The passkey is 0000. If you have a problem, reset the headset. Turn the headset off and hold down the call button for 8 seconds until the headset flashes blue and red signaling that it is in pairing mode for the next 120 seconds. While the headset is in pairing mode, use the phone menu to search for Bluetooth devices and select "220Plantronics." (If the headset is already listed in the Bluetooth menu, delete it before searching to pair the device.) When prompted for a passkey, enter 0000. Headset will falsh blue when paired successfully.
Nov 14, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth
Click NEXT.
Dec 18, 2007 | Computers & Internet
LOGITECH BLUETOOTH MOUSE
Click NEXT.
Dec 01, 2007 | Logitech 931249-0403 Mouse
Maual for Motorola H350 bluetooth headset
User Manual for the Motorola H350 Bluetooth headset!
http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/US-EN/H350_QSG.pdf
Jun 08, 2007 | Motorola Mobility H300 Wireless Headset
Harman JBL Pulse Logo
87 people viewed this question
Top Harman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harman Audio Player and Recorder Expert? Answer questions, earn points and help others
