Question about Kenmore 63662 / 63664 / 63669 Microwave Oven
Light bulb needs replaced - Kenmore 63662 / 63664 / 63669 Microwave Oven
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
Oct 06, 2008 | Neff Microwave Ovens
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
I need to replace the cooktop light bulb-mmv5208ww
You should try to at least find the same wattage. The light bulbs are not dangerous safety hazards if they are made to fit microwaves.
Nov 07, 2013 | Maytag Appliances Over-the-Range Microwave...
Light bulb
follow this steps and fix it. God bless you
If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    How do i change the bulb on ag821azh microwave x2
    follow this steps and use the VOM for fix it. God bless you
    Light Bulb
    If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
    Main Control Board
    If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
    Light Bulb Socket
    If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
    Jun 19, 2013 | Microwave Ovens
    The lamp of won't work
    follow the steps and fix it. God bless you
    ight Bulb
    Main Control Board
    Light Bulb Socket
    Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
    Frigidaire microwave oven
    Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
    To replace the light bulb to the over the range microwave you will need to follow the steps below:
    1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
    2. Remove the vent grill mounting screws.
    3. Pull the vent grill away from the unit.
    4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
    5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
    6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
    7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
    Note: DO NOT USE BULB LARGER THAN 30 WATTS.
    Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
    How to replace burned out light bulb
    You need to remove the top cover to access the bulb. That is the only way on most microwaves.
    Dec 02, 2011 | Emerson MW8107WA Microwave Oven
    Kenmore 63662 / 63664 / 63669 Microwave Oven Logo
    22 people viewed this question
    Top Kenmore Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Jaime Hernandez
    Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
