Question about Wahl 9865-217 Beard Trimmer
Putting Blades Back Together
I have looked at other posts, but my four pieces seem to be different: Top blade, bottom blade, white piece, spring. How do I put it together?
SOURCE: My friend took hers apart to clean and did not pay
how do i reassemble the wahl pro series pet groomer
Posted on Oct 18, 2009
askmannyssha
  • 76 Answers
SOURCE: I took the bland off of my wahl model 9860-1101.
Your best bet is to send it to www.mannyssharpening.com Contact mannyssharpening@yahoo.com they are a Wahl Dealer they have all the parts for Wahl clippers.
Posted on Mar 30, 2010
SOURCE: I have a Wahl Designer
Check out my video on how to install a Wahl Blade this may help you. Manny's Sharpening.com
Posted on May 15, 2011
SOURCE: Wahl 8550 Pet Clippers Won't Work
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
Posted on Aug 22, 2011
SOURCE: How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Posted on Oct 09, 2011
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
How do remove the blades from the Rival 1220 model electric knife
I had the same question and finally figured out the answer. To remove the blades on the Rival Electric Knife 1220, first you must locate the piece I am going to refer to as the COLLAR. The collar is located above the "ON" button - toward the blades - but is not part of the blade. It is in between the main machine and the blades and kind of looks like a collar -it also looks like part of the main unit but when pushed from the top will move. On my 1220 it is the same color as the bottom of the machine. Once you locate this secret piece, the rest is quite simple. First-make sure the unit is unplugged then Just place your thumb on top and push the collar down-towards the sharp edge of the blades-and pull the blades out. To reinsert, line the blades up and snap them back into place.
Feb 16, 2013 | Rival Electric Carving Knife
How do reassemble the blade for Wahl 8552
I had the same problem with the Wahl Pro Series Rechargeable model 8552, and called Wahl service. Here is what I learned:
Never unscrew the screws on a Wahl blade (they use those funky nonstandard screws to deter you) -- that's the main thing. The whole blade assembly is supposed to come off by pulling it up and off from the teeth.
But, if you did it (as I did), you can put it back together this way:
1. Place the large blade down on the table (Wahl logo down), and place the small blade on top of it (if you look carefully, you will see how it lines up).
2. Insert the spring points into the two holes of the white plastic part (on mine, the spring kept slipping out and I finally used a drop of superglue on each hole until it would stay in long enough to complete the assembly). Place that piece on top of the small blade (see photo).
3. The bent metal piece with the two screw holes then gets placed on top of the large blade, with the center ridge of the bent piece over the straight center portion of the spring -- so that you have to hold it in your hand and push it together against the spring in order to align the holes of the entire thing. As you are holding that, put the screws in from below and tighten. It's awkward and if you are like me, it will take several tries before you can get it all lined up correctly and tightened. The photo below is what the final assembly looks like before snapping it onto the clipper.
3. Clip it in: At the top of the assembly in the photo below, notice the small bent metal piece that will fit into the back of your clipper in the hole. Once you fit that properly, push the whole assembly down onto the clipper until it snaps into place.
Aug 03, 2010 | Wahl Health & Beauty
How to reassemble my wahl clipper model 8081
Okay, if you took this machine apart don't worry. You would have noticed when you loosened the first two screws closest to the blade (but still on the body of the trimmer) a small white part of the trimmer flew out...you were probably think wtf? Yeah, okay. If you took all four screws out, make sure you align the cord within its allocated space on the frame and screw in the bottom two.
1. Now, leave the top two screws about 75% loose so that you can slip the white piece back.
2. You will notice that there are two prongs sticking out of the hole where the blade is suppose to go. Make sure the "Detailer" enscribed on the front of the trimmer is facing the ground (or opposite yourself). Align the white piece so that the groves are facing the prongs and the other half of the white piece is facing yourself.
3. Slide the white piece down as far as reasonable, without forcing it. There is a little hook on the white piece, and a corresponding groove on the casing of the Detailer. Make sure that you align the white part so that the hook aligns with the groove, also make sure that you have aligned the groove on the back side of the white piece with the small round tip of the motor.
4. Okay, so this is the tricky part, you will probably be saying...the white piece is still sticking out. Well this is initally why it flew off when you took the machine apart. The blade acts a spring load for the white piece and the top two screws on the casing holds the remaing pressure forced on the white piece. What you need to do now is align the blade and its screws with the corresponding holes on the maroone casing and push the front of the blade down on the white piece and tighten the screws. The machine should now be working.
Hope this helps.
Oct 18, 2009 | Wahl 8081
I had a one hook up on it and the whole blade popped off how do i put it back on
place the short blade on the bottom over the oblong piece then place the larger blade on top and screw back together, if there is a piece of foam inside make sure that is under both the blades and around the oblong piece (refered to earlier) which is sticking out of the top of the unit
Jul 28, 2009 | Conair HCT-426 Hair Trimmer
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
3F blade, took the blade out to clean, can't get back together
That's probably the blade guide. It goes on the "spring"; the piece that holds the cutting blades together.
The blade won't work without it.
Oct 29, 2008 | Oster 76076-010 Hair Trimmer
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
I have broken my HP Photosmart R817
I just fixed mine and what came out of the end of the lense housing was the shutter assembly. Your camera will still work but the shutter will not operate for protecting your lense.
What was on the ground from the shutter assembly looked like six parts but actually there's eight:
1 - Front round plate (what you see if shutter assembly was still in the lense housing).
2 - Hair size springs that hopefully stayed in the sides of the front round plate. IF NOT OR EITHER ARE LOST, THE SHUTTERS CAN'T BE SET TO CLOSE SO SKIP THE STEPS BELOW ABOUT INSTALLING THE BLADES.
1 - back round plate (black with four tabs).
2 - Larger L-shaped blades.
2 - Smaller L-shaped blades.
Place the front round plate with cosmetic (engraved 'PENTAX...) side down and look at the inside for two round mounting posts on the left and right. You will be using the larger of the two posts on each side for placing the L-shaped blades.
Place the larger L-shape blades with the hole end onto the posts. Blades should swing freely and their backs match with the shape of the inside of the front plate when open.
Place the smaller L-shape blades on top of their respective larger L-shape blades with the hole end onto the same posts used in the last step. Blades should swing freely and their backs match with the shape of the inside of the front plate when open along with the larger L-shape blades.
Springs (long ends) will need to notch into the smaller L-shape piece end (nearest the hole/post end). This is a real trickly part of the assembly and I used two tools like large pins or needles to pry the spring into the notch. If you can't do this, no sense in even leaving the four L-shaped blades inside of the front round plate since the shutter will not close properly without the springs.
Align and snap the back round plate tabs onto the front round plate. The shutter assembly is now ready to put back into the lense assembly.
MAKE SURE THE CAMERA IS IN THE OFF POSITION AND THE LENSE ASSEMBLY IS RETRACTED!
Align the front of the shutter assembly with the engraved wording properly oriented (not sideways, not upside down, etc.) and press gently into the lense assembly until completely in the end of the housing.
If blades were installed properly, they will open when the camera is turned on, and close when the camera is turned off.
If blades were not installed, the empty shutter assembly (back round plate snapped onto front round plate) can still be pressed into the lense housing...the shutter will just not work and the lense will always be exposed. Actually, this is one helluva lot easier than fixing the shutter assembly and not the end of the world for your camera's operation!
Mar 23, 2008 | HP Photosmart R817 Digital Camera
Wahl 9865-217 Beard Trimmer Logo
98 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
