Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool WSF5574 side by side fridge/freezer water filter indicator flashing red. I have changed the filter drained off 14 ltrs of water tried resetting the alarm but indicator is still flashing red. Why ?
  • 8 Answers
SOURCE: whirlpool side by side fridge freezer
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Posted on Oct 19, 2007
peyton32034
  • 410 Answers
SOURCE: how to remove water filter on Whirlpool ED2VHEXVQ00
the filter is located in the front of the unit just below the freezer door whirlppol has 2 filter options one has a push button next to the round filter cartridge that whne pushed releases the filter. the other option is a twist out filter simply turn 1/4 tun counter cloclkwise and the filter will come right out.
after replacing filter run aprox 1/2 gal of water to clear air and remember to reset filter monitor according to your owners manual
Posted on Jan 21, 2009
SOURCE: how to reset water filter indicator on whirlpool
Resetting your "change filter" light:
  • Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
  • If the fridge has a filter button, press and hold it for 5-10 seconds.
Posted on May 17, 2009
SOURCE: WHIRLPOOL AMERICAN SIDE BY SIDE FRIDGE /FREEZER
I had probably the same problem. After a little discussion with the factory they sent a technician as a "Good Will Gesture." The technician told me it was the control board down by the compressor. I overheard a conversation between he and his central repair office that it was a common problem. The factory would not admit it. I have a feeling the electronic control board he replace (which would have cost several hundred bucks) was probably made in China. Now I'm having more problems with my Ohio made Whirlpool side-by-side. The freezer is working fine, the fridge is not very cold. By the way, the internal lights was one of the keys to the problems.
Posted on Jul 10, 2009
SOURCE: whirlpool S20B RSB21
If you look on e-bay, there is a chap in the UK selling repair kits. If you are reasonably mechanically minded and handy with a soldering iron, and happy to remove components on a PCB and replace them you can fix all of your issues in about an hour. The kit costs £35 with full instructions and also you can phone him for advice. It consists of a number of capacitors (as per solution #1 plus several others). I fixed mine over the weekend and am delighted with the results, no need to pay hundreds for the the boards from whirlpool!!
Posted on Feb 08, 2010
I have an american style hotpoint fridge freezer MSZ902DF which has had a water filter change as blue light on but despite following process the light has now turned to orange. Can anyone advise what we...
Refrigerator - Water Filter Indicator Light Will Not Shut Off After you change the filter the RESET WATER FILTER must be pressed and held until the red light goes off.
Note: If you do not hold the pad in, the light will stay on. Also, if you hold the pad in for a long period of time, the light will go off and then come back on.
If this does not turn the light off, having it checked by a service technician is recommended
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Mar 04, 2015 | Hotpoint Refrigerators
Whirlpool conquest side by side. Ice began melting and red light for filter replacement was on. I changed the filter but it didn't seem to fix the issue. Few days later everything began working fine but...
Turn the temp control to max, does the compressor come on? If yes feel the discharge line at the back of the compressor, is it nice and cold? If yes you can eliminate the simple items, make sure all the fans are working inside the fridge and at the rear of the unit. Check to make sure the defrost drain/trap are clear. Let it run for a while, then drop the temp to the usual setting it, and see what happens.
Feb 26, 2015 | Whirlpool Refrigerators
Whirlpool Gold fridge not working at all even at maximum coldness adjustment, while freezer is fine. Red light on, indicating bad filter, but frdge not connected to water supply, so changing that wont fix...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Refrigerators
My side by side fridge freezer is flashing CF alarm code. What does this mean
Change filter most likely this is the filter for the water.Meaning dirty water and foul tasting ice.Some filters are located in the front easy to reach areas at the bottom near the floor usually left side under freezer.
Nov 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
How to reset water filter indicator on whirlpool american fridge freezer
Mar 09, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool s20b fridge/freezer
858615215011 temp. indicators and night light flash continuously.
Mar 27, 2008 | Refrigerators
Whirlpool side by side fridge freezer
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
59 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
