Tv rca tr29e26
Tv shuts down after a few seconds
3 Suggested Answers
  • 3 Answers
SOURCE: rca 27v414t shut off by it self after a feww seconds.
After replacing the flyback transforer and horizontal synch transistor you will need to adjust the flyback transofrmer as follows:
Turn each setting to just above mid point clockwise, turn the tv on and you should see a white screen with retrace lines in it just before the tv turns back off. set yourself up with a plastic screw driver and prepare for adjusting the focus(top adjustment) turn the tv on and adjust the focus by looking at the pixels on the screen. repeat as needed to complete.
Next setup for the brightness (lower adjustment) turn the tv on and adjust the brightness to where the screen appears to be black(no haze or lines). After the tv turns off wait a few seconds and turnit back on, it should stay on, if not then the brightness setting it too far one way or the other and "TecniklyNuts" it correct, the system detects the setting out of range and turns the tv off. Repeat the two adjustments until the system stays on.
Posted on Feb 08, 2009
SOURCE: When I open my RCA
IF LED IS BLINKING then............. usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound ..but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective ..........IF LED IS ALSO OFF then on main board in power section area some component is deffective ... MAIN BOARD SHOULD BE CHECKED COMPLETELY........ so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 ( US$ 12) ........iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com ) .....i don't have any idea about EHT component's price & service charge in your area........this problem cannot be solved by user unless user is a technical person having idea about components (resistors, transistors,diodes,...etc..), having multimeter , soldering iron & other tools...so my suggestion call TV service engineer or contact RCA service centre.........
Posted on Apr 22, 2011
Testimonial: "Thanks a lot for your help Carole"
RCA 40 INCH SMART TV TURNS ON THEN 30 SECONDS TURNS OFF
Not knowing the age of the TV, a common cause for a set to run a few seconds then shut off is bad capacitors, pull the back and see if there are some swollen ones, or just chance the power supply and that should fix it
Nov 08, 2017 | RCA Televison & Video
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
My RCA TR29E26 showing no colour
There are so many reasons for the absence of color. Contact any service technician. http://electronicshelponline.blogspot.com/
Jul 20, 2014 | RCA Televison & Video
Tv starts up and shuts down every 3 seconds
Short circuited component/s at its main board. Contact any service technician.
Feb 03, 2014 | RCA F19426 19" TV
My RCA hdtv d52w23 will turn red screen when you turn it on and a few seconds later it will shut off. Whats wrong with the tv? Ive looked inside it. The red circuit board has a burned mark on it, but I...
If excessive red the set will detect too much current being pulled and shut down----Try to Google the model number with "parts" or if that fails try to contact PTS Electronics who repairs/rebuilds all kinds of circuit boards.
May 14, 2012 | RCA Televison & Video
RCA rear projection TV power light blinks for a few seconds but
Look on Deflection board If cp150 capacitor is puffed up on top it is bad there is 3 caps to replace cp150(,2200uf 16v ) cp114,cp120.(220uf 35v). The SSB board can also shut set down.
Jan 04, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV trys to come on but colors streak down screen for few seconds then it shuts off (2006 tv)
I decided not to sign up at this time for premium assistance because I know that it is either related to flyback transformer or regulator. Because I do not have required test equipment to perceive which, I opted to take it to the shop.
Jul 07, 2008 | RCA 32V524T TV
RCA 52" Model # D52W19
when the processor on the set detects a problem it will shut the set down for safety. it could be many things. technicians have a device that can read the errors that the processor has detected.
Nov 23, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
