Question about CyberPower Computers & Internet
Bluetooth & Wireless switch
I brought a HFX7-500 and its great. My only issues is that I can't turn on wireless and there seems to be no bluetooth. Can you help?
    New Friend:
Want rid of match.com popups
Posted on Feb 15, 2014
Kaoeria
  • 36 Answers
SOURCE: Wireless switch
Make sure you have the latest drivers, router and NB.
Does it connect on reboot with the SSID off?
Does it work on repair?
if so, check your energy settings, some times they power down the wireless to save energy. There are also settings on how it behaves.
Posted on Jan 04, 2008
SOURCE: Toshiba wireless mouse
Did you check the Toshiba web site?
Posted on Mar 10, 2008
Panth3on
  • 71 Answers
SOURCE: no sound
go into the control panel - go into sound & audio devices - go to the audio tab - you should see default sound device with a pull down menu - pull it down and see if you have any other devices for audio playback - but first you need to enable your bluetooth speakers or you will never hear anything if you can change devices - same goes for the default recording device and default midi device - hope this helps you out.
Posted on Sep 03, 2008
yboyandrei
  • 828 Answers
SOURCE: Can i use Bluetooth USB Adapter to connect PC to wireless router?
Bluetooth is not capable of connecting device such wireless router, only is to allow connect from Bluetooth to Bluetooth connection, but Wireless Router can detect such USB Devices which called USB Wireless LAN. You have to buy it to connect 100% on your Wireless Router. Good luck!
Posted on Aug 03, 2009
NONOTHIN
  • 51 Answers
SOURCE: Dell Wireless Keyboard
Turn your computer off
Put the Keyboard and switch the computer on
Posted on Oct 24, 2009
Have bought a Braven wireless speaker (bluetooth) for my QT 5500. It sounds great when plugged into laptop but can't seem to get bluetooth to work. Will I have to buy a dongle
All depends, Does your QT 5500 have bluetooth Adapter? Bluetooth Software? I looked at the specs, I don't see Bluetooth listed, but doesn't mean you don't have it. In Device Manager, is Bluetooth Listed?
Nov 30, 2012 | Computers & Internet
How do i turn on the wireless
Good day, you can switch on your wireless by hitting the wireless switch located in front of your laptop. The switch is located prior to the right speaker, after the bluetooth switch. You can fold your laptop to avoid confusion and then lift it up like a sandwich facing you, with taht you'll be able to see the button/switches I am referring to. Hope this help you a bit. Have a great day. By the way it will give you a pop up message saying that you have enable or turn on the wireless.
May 23, 2011 | Acer Aspire 5500 5570-2609 Laptop
How do i switch on the wifi in my dell inspiron 6400? The Fn + F2 command is switching on the bluetooth only
You can turn on/off Bluetooth and Wireless using the Fnand F2 key.
To enable or disable wireless networking, press <Fn><F2>.
Turns on when a card with Bluetooth® wireless
technology is enabled.
NOTE: The card with Bluetooth wireless technology is an optional feature, so the ordered the card with your computer. For more information,
see the documentation that came with your card.
To turn off only the Bluetooth wireless technology
functionality, right-click the
area and click Disable Bluetooth Radio.
To quickly enable or disable all wireless devices, press
<Fn><F2>.
Please refer the page #69 to 74 for complete information on the Wireless and Blue-tooth
http://support.dell.com/support/edocs/systems/ins6400/en/om/MD402AO3.pdf
Jun 28, 2010 | Dell Inspiron 6400 Notebook
My wireless adaptor isn't working. I have an Acer travel mate5720 which has a switch on the front for blue tooth & wireless access. Bluetooth works ok but the Wireless adaptor won't i have checked in...
This model does have wireless. I had a similar problem a little while ago, I plugged the unit in to a wired connection, and on it's own, disabled the wireless adapter.
Go to start--> control panel--system-->hardware-->device manager
look under the "network adapters", there should be a wireless adapter or 802g something something, right click on this item and click "enable".
You should then be able to browse for wireless networks now.
Jan 06, 2010 | Acer TravelMate 5720-6635 Notebook
The bluetooth turns on using FN + F11 it should turn the wireless too but doesn't MSI U100
As per the manual the FN and F11 keys turn on both Bluetooth and Wireless so you need to try it will turn bluetooth and then it will turn on wireless, you can check them by LEDS
Press and hold the Fn button, and then press the F11 button
repeatedly to enable or disable the Wireless LAN or Bluetooth function
recurrently.
Wireless LAN and Bluetooth:
�� Wireless LAN LED indicator glows green when Wireless LAN function is
enabled.
�� Bluetooth LED indicator glows blue when Bluetooth function is enabled.
�� Both LED indicators glow green and blue at the same time when both
functions are enabled.
�� Both LED indicators go out when both functions are disabled.
�� Note: For flight safety consideration, make sure these two LED indicators
go out when you are in flight.
Let me know if you are able to turn the wireless on
Also i will suggest you check in device manager that you wireless adapter is enabled
Regards
Dec 02, 2009 | MSI U100-001US Netbook
How do u turn off the bluetooth on the msi wind netbook
Press【Fn 】+ 【F11】for Bluetooth \ WLan functions
I believe that the number of times you press the FN+F11 button, these would be the results. I hope this helps you.
1. Both Bluetooth, Wireless LAN Off
2. Bluetooth Off, Wireless LAN On
3. Bluetooth On, Wireless LAN Off
4. Both Bluetooth, Wireless LAN On
Oct 20, 2009 | MSI Wind U100-004US Notebook
How do I turn on the wireless?
Hold the FN key, and the F8 key (the one with the antenna icon).
Sep 30, 2009 | Toshiba Satellite A135-S4477 Notebook
How do I switch the bluetooth on on my U90?
it should have a button on your machine. locate it on the side and switch it on.
Jun 30, 2009 | Computers & Internet
I have problem with my vostro 1510 wreless, by switching the wireless and bluetooth key on, only the blutooth devise is turn on.
The Dell QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
It is known to glitch when power is removed from the machine while the wireless is in use.
Please let us know if you have any futher questions. If this information was helpful, please take a moment to rate the solution. Thank you.
Apr 23, 2009 | Dell Vostro 1510 Laptop
Computers & Internet Logo
32 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
