Question about Building Materials
How do i put a door in a wall
Need access to an addition on my house was thinking bout puting a door through the wall
    Filmmaker:
    Uploaded 5 video answers.
  • 7 Answers
You first need to determine if the wall you want to cut through is load baring, if so you need to restructure the hole you will make see engineer for exacts as every project differs. once all of that has been established you determine the size of the door you wish to install, be mindful of size if you plan to put any large furniture in How do i put a door in a wall - 2_18_2014_5_40_04_pm.jpg
Posted on Feb 18, 2014
  • 4 more comments
  • Larenzo Morris
    Larenzo Morris Feb 18, 2014
    You simply frame the opening that was made usually using 2x4 if your door thats being installed is 32 inches you will need a opening of at least 35 1/2 factoring the wood which will take 3in2ches this leaves you with 1/2inch you will use door shims to fill that void as to make sure your door is level and plum.
  • Larenzo Morris
    Sorry typo that 35 1/2 should be 32 1/2
  • Larenzo Morris
    Sorry 35 1/2 is right
  • Aaron Deathscars Oct 13, 2014
    Wow Morris it's been a long time coming with this reply.. First thanks your information was extreamly helpful and taking direction from your advice I did infact find if to be load bearing (which thanks to saving me a way bigger problem ) so yes I got the door in and framed the spacing where I cut out and installed door.. Thanks for helping me man... Aaron
  • Larenzo Morris
    Larenzo Morris Oct 13, 2014
    Glad I could help
    Problem Solver:
  • 12 Answers
If the wall is a load bearing support wall then you must make sure you put a double 2x12" above the door opening after you cut the hole in the wall for the door. I assume you are installing a regular interior door which will be a 30, 32 or 36" wide door. On each side of the hole you cut, you put double 2x4"s on each side of the wall opening and where you are going to screw in the door jams. Now one of the 2x4's will go all the way to the top plate. That is the double 2x4's at ceiling level that holds the walls together. The second 2x4 will face the door opening. You make the other 2x4 about 11 1/4 inches shorter than the first one and nail them together. Do this on both sides of opening. The reason for this is you are going to put the double 2x12's on top of the shorter 2x4 and this will support any load bearing wall and keep it from sagging. You also nail the double 2x12's to the top plate above the door opening. The reason I say cut the 2x4 eleven & a quarter inches shorter is because a 2x12 is actually 11 1/4 inches wide. Also I would buy a pre hung door. it is a lot easier to install.
Posted on Dec 08, 2014
Ipad 4 very slow wifi takes forever to download any sites I think because in my bedroom bad area
move closer to the wifi hub.
if the hub is over loaded (is it yours, or at starbucks?)
state exactly where you are, so we can answer.
and if at home ,state wifi point, brand and model.
and what internet you have , slow DSL, fast, cable or FIOS.
Oct 01, 2013 | Apple Ipad Tablet ( 3G , wifi , WiFi + 3G...
Chamberlain whisper drive bulbs keeps burning out
I had a similar problem on my Liftmaster units made by Chamberlin. I would leave the garage door open for hours during the day so our dog and children can enter the house through our garage and laundry room. Everytime they come into the garage the Light's would go on because of the safety sensors are "tripped" at the bottom of the garage door tracks.
I turned off this feature and my lights are lasting much longer now. Over 1year in fact. To turn off and on this feature, make sure the opener light is off, then Press and Hold the Light Switch on the Wall Control Until for about 10 seconds till the light goes off. This deactivates this sensor from turning the lights on, but does NOT deactivate the sensor for Stopping the door if something is under it. Safety is still preserved.
Additionally, my door opener would vibrate while operating, and need to be aligned - I did this and also prevented the bulbs from "shaking". As we know the light bulb filaments are brittle especially after some use - this I think also helped lengthen the life of my lights on the opener.
Jun 30, 2012 | Chamberlain 1/2-HP Whisper Drive Belt...
Garage door oppener
did you try new battery for the old wall button? other electronics work in that area (like a wall outlet?)
Jun 30, 2012 | Home Security
I'm thinking of getting the full reclining lazyboy loveseats, how much space I need to leave between the chairs and the wall?
If it is fully reclining you need to leave a little bit more than the height of the chair's back. For example: if the back height is 19", then you need to leave about 20" between the chair and the wall behind it.
May 29, 2012 | Furniture
Hi, I have a 2Wire 270 DSl Modem I had bought through Qwest since they are my ISP. My home is a 1500 Sft Ranch, if the modem is in the bedroom and the Mac Book is in the family room down the hall the...
If the walls in your house are made of lathe and plaster or concrete block, then the performance of WiFi through all the walls in your house will be very bad. The signal that you are receiving from your neighbor's modem is probably only going through two walls (the outside wall of their house and the outside wall of your house), while the signal from your modem is probably going through at least 4 or 5 walls.
I suggest that you do not buy a new modem, but buy a wireless access point, a spool of CAT6 cable and two Leviton RJ45 wall jacks. Run the CAT6 cable from the modem to your bedroom, install the Leviton RJ45 jacks on both ends of the cable, and then connect the wireless access point to the the jack in the bedroom and the modem to the jack near to it.
This will expand the wireless coverage in your house and allow you to buy much better wireless device than QWest would ever sell to you.
Here is a suggestion for Wireless Access Point.
You can buy the CAT6 cable and Leviton RJ45 jacks at Home Depot or Lowes.
Dec 30, 2010 | Computers & Internet
I have an old Victorian house with an apartment in the back above the barn/garage. I am trying to get wireless internet connections to all sections of the house but my current router (3 years old) is not...
Hello.
Yes. As you mentioned, you have a Victorian house, with very thick walls. I'd suggest drawing a diagram showing the rooms and floors that need access.
First, if possible, I would place your router in a centralized location, if all 5 people need similar strength access.
Then what you need are multiple repeaters to go with your router. Place them strategically, so that the wireless access signal can bounce off of them and go around walls, instead of through walls and floors.
Hope this helps.
Nov 22, 2010 | Computers & Internet
Door does not shut completely
OVEN DOOR HINGES WILL NEED REPLACEMENT IF YOU PUT ADDITIONAL WEIGHT ON THE DOOR THEY WILL SOFTEN THE SPRINGS AND THE DOOR WONT FULLY CLOSE.
May 29, 2010 | Electrolux 30" Built-In Double Electric...
HBW0777 Not working
It sounds like the trolley is jammed against that bolt in front of the motor housing. If so, remove the bolt and then run the opener until the door closes. Now locate the 'up limit' control on the side of the motor housing and turn it 2 full turns in the opposite direction of the arrow printed on the cover.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Access Master Garage Door Opener opens by itself
The most common cause of this is a bad wall control or the wiring going to it. The wall control goes bad from use and the wiring sometimes has intermittent short caused by the staples the installer used.
Jul 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
I think there are socks between drum and walls
There is usually a small access door in the back of the unit for removing these items. If not a separate door then removing the vent pipe housing will allow access. UNPLUG the unit first
Nov 29, 2008 | Kenmore 24032\24036 Top Load Washer
Building Materials Logo
400 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
