Question about Whirlpool ED2KVEXVQ (217 cu ft) Side by Side Refrigerator
Does not dispence ice - Whirlpool ED2KVEXVQ (217 cu ft) Side by Side Refrigerator
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Whirlpool ED2KVEXVQ (217 cu ft) Side by Side Refrigerator Logo
12 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
