Question about Cameras
Canon pc1431 camera We get the message "Vervang de batterijen" (replace the batteries) all the time, also after replacing the batteries with freshly charged ones. It is impossible to make photographs.
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Misschien zijn alleen de contacten in de batterijhouder vies.
Of some is een van de herlaadbare batterijen gewoon op.
Batterijen moet je goed bij elkaar houden. Noot verschillende soorten door elkaar gebruiken en ook liefst niet een kopen om een defecte te vervangen, maar de hele set.
Liefst 2 of 4 batterijen samen laden, zodat ze dezelfde capaciteit hebben en houden.
Mocht overigens een of meer contacten in de camera vies zijn, kun je die met een wattenstaafje reinigen. Nooit met iets scherps in of bij de camera komen.
Succes
Posted on Feb 15, 2014
SOURCE: Canon A95 gone dead
I ain't so lucky I'm in the UK too!!!! Generally speaking the cost pf packing, shipping repair, at any level is well on the way to the price of the next more recent higher specification device. Judging by the way the Megapixels go up by the week seemingly, settling for a replacement camera is usually the best option. I had a cheap[old] Fuji come my way because it had gone blurred and blue - sure sign of a CCD failure as this was at some time the subject of a recall for the problem I checked out Fuji Their response was to say no longer repaired but has a 1/3 off a new camera when I quoted a reference number. That seems to be the way to go.
Posted on Jul 30, 2007
SOURCE: canon powershot g5 - battery charge
Take out the battery and put it back and than recharge again. Some times in case of G5 it happens that the camera battery is not properly charged and the indicator shows that its fully charged (i.e. Green light) In such cases battery need to be taken out and than put back again and recharged
Regards,
Zain
Posted on Mar 20, 2008
SOURCE: CAMERA battery low message with new batteries
I have the same problem with mine!! Had it about 14 months now too!! Glad I'm not the only one... I don't know what to do! I have gotten brand new rechargeable batteries and instead of getting 250 shots, I only get like 20!
Posted on Jul 25, 2009
SOURCE: I have a Canon SD1000 battery pack issue.
I have a Canondigital ixusi which had the same problem and I purchased three new batteries, but found that all of them showed the "replace battery pack" message when fully charged. I have solved this problem by cleaning all the terminals on the batteries and in the camera very thoroughly with alcohol and Q-tips. Even though the terminals look completely clean, there must be a slight film which is preventing good contact. The contacts in the camera are spring loaded and I suspect they are not making a very good conection to the battery so any contamination is making a high resistance to the flow of electricity. Hope this helps - it worked for me.
Posted on Nov 27, 2009
  • 11967 Answers
SOURCE: I have a Canon Power Shot SX120 IS camera. I
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 28, 2010
Canon pc1431 camera
The battery is either flat or unusable. Try another battery if possible. Depends how old the battery is. They can just fail if they are not cared for correctly. Full charge and Full discharge every so often. Older batteries used to loose their capacity due to what was termed battery memory. Modern batteries are much less prone to this effect where the battery does not last as long as it did when new. Modern batteries just fail to function after a time.
Dec 20, 2013 | Cameras
System error
Als je nog wel meldingen op het scherm ziet, werkt er nog wel iets. Maar toch system error, kan van alles betekenen. Zo kan er iets vast zitten (de lens b.v.) maar probeer eerst de batterijen eruit te halen en ze na een korte tijd weer terug te zetten. Mocht er intern een chip of een flatcable gebroken of gescheurd zijn, vrees ik dat reparatie niet meer mogelijk zal zijn.
Nov 06, 2013 | Konica Minolta DiMAGE Z5 Digital Camera
Date/Time Resets
Hi, inside the battery compartment with the battery's out, there's a little flap with a watch battery inside replace and all will be fine..
Thanks
Mark
May 03, 2010 | Canon PowerShot SX100 IS Digital Camera
Fresh batteries, clear playback, but still won't take a picture
Change the teeny date/time battery--dig it:
http://www.fixya.com/support/t2374899-change_batteries_message_even_new_nimh
I was all set to send my camera off to canon for repair when I happened across that solution. I don't have a replacement on hand, but just removing that battery allows me to take pics again.
Nov 01, 2009 | Canon PowerShot S2 IS Digital Camera
I have a Canon Powershot A550 and I recently dropped it on a night out. Since then, now matter how many times I have changed the batteries to fresh Alkaline batteries, the camera tells me to "change...
The internal connection is damaged or circuit board is damaged . You try to tap on the sides of camera and check whether the message is disappeared .
Also possibility that battery contact is damaged so try giving power to camera through power adapter . If this works then you need to replace the battery holder .
If your problem still continues then you need to take to service center to get it repaired .
Thanks for using Fixya
SAM ANDERSON
Dec 11, 2008 | Canon Cameras
Camera won't turn on
Try replacing the date/time battery located in the main battery compartment. Also, simultaneously remove the lens. This will be like a master reboot for the camera. Replace the date/time coin battery, the main battery (freshly charged) and lastly the lens.
If this doesn't work, send it in for service. If you are just slightly beyond your one year warranty, Canon may allow a grace period especially if you can provide a receipt. If you can't find a receipt, give them the approximate date of purchase when you send in the camera. You will need to call them or set up service online.
Hope this helps!
Apr 25, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Powershot a540 "cannon"
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Dec 21, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
eNDi
Oct 17, 2007 | Canon PowerShot S45 Digital Camera
Cameras Logo
208 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
