Question about Element Electronics Televison & Video
No picture,but we have sound any reset button?
No picture but we have sound any reset button?
Apex ld4688t tv is there a reset button no sound or picture
Sounds like main power regulator board fault. There is no such reset button [external] to modern TV. You should have to enter its service mode option to reset it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 21, 2015 | Televison & Video
Jvc hd-61Z786 REAR PROJECTION TV . is dark. replaced the lamp. did not help much
all u have to do is to
Reset Picture and Sound Adjustments
1.Press the "Menu" button.
2. Press the "CH+" or "CH-" button to "Reset" listed on the display.
3. Press the "Volume+" or "Volume-" buttons to move left or right to enter your Reset selection. The Reset will reset all of your picture adjustments, including the color, brightness and tint to the default settings. Reset also resets your sound adjustments to the default settings, like the balance, bass and treble.
4. Press the "Menu" button to complete the resetting process
Feb 23, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
Sound but no picture
You need to reset your video.
Hold down the power button and turn off the system. Once the red light is solid, hold down the power button and it will cycle on and then back off with a few beeps in between. Now let go and turn it back on, this should have reset your video. If you have any further issues, google how to reset video on PS3, there are plenty of videos out there.
- You've been helped by a Wired Extreme technician.
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Have no picture or sound on ps3
First thing to try is a manual video reset.
While the PS3 is off:
Hold down the power button until you hear the second beep, quickly release the button.
This will reset the video.
If that doesn't work, remove the hard drive from the system and try again.
Let me know what happens.
Mar 12, 2009 | Sony Playstation 3 (PS3) Console
No picture after resetting by pressing stop button for 20 sec
Problem fixed: I realized that the problem was that with resetting the player it defaulted to the standard video ouput ie no longer sending signal through the component video. I used a standard video cable and connected player to tv with that and it had a picture. Then I changed the setting to progressive output and got picture signal through the component cable again.
Aug 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
My Television Turns on, but there is no sound or picture, Is there a Resent Button?
There isn't any reset button. All you have to do is to take out the power source. Anyway, double check the wires... are you sure all are well connected?
Dec 19, 2005 | Hitachi 55FX20B 55" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Element Electronics Televison & Video Experts
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
