Question about Primo Grills And Smokers Primo Top-Load Water Cooler, Stainless Steel/Black
Cold water not working
No longer getting cold
The water no longer gets cold . What do I check ? Thanks !!
On a washing machine?
You have a hot fill inlet, you have a cold fill inlet. The controller dictates how much hot water and cold water to get the right temperature for the wash you have chosen. This is tested by the thermostat in base of the drum. The heater then warms the water to the correct temperature for the full wash.
Some washers are cold fill only and the heater in the washing machine does all the work. The wash cycles take a lot longer.
If you are in fact talking about a water cooler not getting cold, check the air filters and for dust on the compressor fins.
Jan 13, 2016 | Washing Machines
Cold water fill does it heat to temputure requied?
If your washing machine has inlets for both hot and cold water, you should connect both if possible. If you can only connect cold water, the washing machine will still work and heat to the required temperature, but it will need to heat the water in the machine, so the wash cycles will take longer and it will use more energy.
If connecting a hot and cold fill washing machine with cold water only, you will need to connect a Y-Piece for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine.
Please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
MY AIR CONDITIONER IS NO LONGER PRODUCING WATER FROM THE BACK
Check to make sure the filter is clean. If not, remove it, wash it and start it back up.
The water that you have seen comes from the machine cooling the air, the air conditioner literally squeezes the water out of the air. If it's not blowing cold ... no water.
If cleaning the filter doesn't work, you will probably have to have the unit looked at by a professional.
Jul 22, 2010 | Daewoo DWC-084R Air Conditioner
I can't get cold water, no matter which setting I choose.
There is a two way electronic valve right where the water fils into your tub, check the wires going to it first to see if they are disconnected, most likely the terminal is corroded and no longer able to conduct electricity. A new valve is around $60, I used a screw to make mine work after the terminal broke off from being rusted and to allow us to do laundry while I waited for the part o come in, and it is still working that way a year later, the part is in the box waiting until the valve fails again.
Jun 14, 2010 | Maytag MAV7600 Top Load Washer
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
No Cold Water
THE SOLENOID VAVLE IS DEFECTIVE,NEED TO REPLACE IT, ITS WERE THE HOT AND COLD HOSES CONNECT TO BEHIND THE WASHER WERE YOU CLEANED THE SCREEN. NEED TO TAKE IT OUT AND REPLACE. ITS A ONE PIECE IT SHOULD BE RED OR BLUE OR SUMTHIN LIKE THAT.
GET THE MODEL NO AND SERIAL NO AND SOURCE AROUND FOR A REPLACEMENT PART. ALWAYS GO WITH THE ORIGINAL PARTS SO IT WOULD LAST LONGER, THEN TO MODIFY AND COST YOU MORE MONEY, WHEN IT SHOULDNT.
Oct 05, 2008 | GE Profile WPRE6100G Top Load Washer
Primo Grills And Smokers Primo Top-Load Water Cooler, Stainless Steel/Black Logo
756 people viewed this question
Top Primo Grills And Smokers Water Dispensing & Filtration Experts
ray gallant
Bill Boyd
Tom Chichester
Are you a Primo Grills And Smokers Water Dispensing and Filtration Expert? Answer questions, earn points and help others
