Question about GE XL1800 1100 Watts Microwave Oven
Buzzing sound when door is open GE xl1800
When the door is opened on this model MW, a buzzing/grinding sound sounds. It appears to be coming from the control panel.
  • 3 Answers
SOURCE: G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Posted on May 15, 2008
rickzilla
  • 706 Answers
SOURCE: GE Spacemaker xl1800
A simple test is to place a piece of bread in the microwave ( it heats up very fast) and then if your microwave was actually ON and generating RF, the bread would get hot very fast.. If it remains cool then only the fan is on. It appears that you may have a faulty door switch thou because once you open the door, your microwave should be off..
Are you sure the VENT is not on? That blower will operate regardless of the door open or closed so you must switch it OFF.
Posted on Sep 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker XL Microwave Oven Model
Your membrane keypad is wearing out.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
The keypad is part number WB27X10171 and you can get it here for $91.68 plus shipping.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Posted on Jan 31, 2010
Testimonial: "Thank You. "
rylee_smith
  • 8619 Answers
SOURCE: GE Profile Spacemaker XL1800
Hi
Thanks for using FixYa. If it’s a loud hum/buzz sound then 90% it’s usually a bad magnetron and other times it’s a bad high voltage diode. However, from what you have described it seems to be the magnetron. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 29, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: ge spacemaker XL1800 - open the door and it starts
That's a defective electrolytic capacitor on the control circuit board.
We see and repair this a lot nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Oct 03, 2010
Testimonial: "I don't know anything about repairing a microwave, but the advice sounded like I could even do it. Thanks for the answer"
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
XL1800 buzzes but heats
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may have to replace the capacitor too. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
May 11, 2013 | GE XL1800 1100 Watts Microwave Oven
GE Profile Spacemaker XL 1800; Model JVM1860 CD 001; Manufactured Nov. 2001 When opening the door or pressing any menu option, a constant buzzing sound occurs. The unit does not respond other than the...
We see (and repair) this a lot. The problem is electrolytic capacitor that fails on the control circuit board, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year repair guarantee.
Nov 22, 2010 | GE XL1800 1100 Watts Microwave Oven
When opening the door a venting sound immediately starts up.
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Feb 11, 2009 | GE XL1800 1100 Watts Microwave Oven
Fan & Turntable start when door is opened.
sounds like there is a switch that is bad. you can go buy a new MW for about 200$ and in yours if there is a major problem then i would just go buy a new one but might be worth a repair man to come check it out
pleas do not poke around in the microwave as it carries a charge of 5000volts and can kill you even if not plugged in DON'T TOUCH THE WIRES WITH BRAIDS ON THE OUT SIDE if you must get inside of the unit
Dec 10, 2008 | Microwave Ovens
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Ray
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
GE XL 1800 MW recirc motor open and closes flap on its own every 10 secs.
Sounds like the control board has gone bad and will need to be replaced.
Oct 13, 2007 | GE XL1800 1100 Watts Microwave Oven
GE XL 1800 touchpad motor sound
that sound comes from fan motor, please replace or service fan motor ..
Sep 25, 2007 | GE XL1800 1100 Watts Microwave Oven
GE XL1800 1100 Watts Microwave Oven Logo
35 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
