Question about OKI B4400 Laser Printer
B4400 won't pick up paper - OKI B4400 Laser Printer
Canon Mp550 paper jam
If the paper is not being picked up from the tray assembly try applying mild soap to a soft cloth and clean the paper pick up rollers. Do not use rubbing alcohol because it will dry the rubber out so later they won't pick up at all
Sep 18, 2012 | Canon Office Equipment & Supplies
Printer runs but won't pick up paper can not manually feed a sheet either
I would suggest contacting me at http://techrxgb.com We are an authorized OKI Reseller.
If your having pickup in both trays, there could be an issue with the hopping motor not running. What I find in the 4400 series most often, are the rollers wear out and simply "slip" Do you hear it picking up paper at all? Since it is a 4400, you could try adjusting the paper thickness too.
Oct 27, 2010 | OKI B4400 Printer
Drivers
this is the OKIB4400 Direct link for the drivers
http://my.okidata.com/PP-B4400.nsf?opendatabase
select ur Operating system if xp vista. or 7
then select language then download it. and install
Dec 26, 2009 | OKI B4400 Laser Printer
Poor copies with OKI B4400
Possibly a fuser issue. Check by sending a 1 pg document to printer and opening cover when paper picked from tray but before it enters fuser. if image good then problem caused by fuser and you will need to replace. If image bad then possible defect with drum.
Oct 04, 2008 | OKI B4400 Laser Printer
OKI B4400 Laser Printer Logo
88 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
