Question about Goodman GDS80904BNA Open Flame Heater
No power to gas valve after igniter glows - Goodman GDS80904BNA Open Flame Heater
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Typically it should glow for a full 30 seconds BEFORE power is sent to the gas valve to open. This is even after the 'pre-purge' sequence where the inducer starts and runs for a predetermined amount of time to purge the heat exchanger of any residual gas. The whole sequence can approach 3 minutes or more on some models.
Check all connections on the circuit board before assuming the board is bad.
Posted on Nov 22, 2015
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMP075-3 ignition problem
OK, if the furnace is not lighting for even a few seconds, you have either a bad gas valve, bad wire, bad control module or no gas. The pressure switch is not the issue. Check all wires to the gas valve and look for 24 volts across them when the ignitor glows and you hear the click. Then test for 24 volts to ground. It could be a bad ground wire.
Posted on Oct 21, 2008
  • 6 Answers
bad board,i have had several board failures on goodman
Posted on Dec 31, 2008
  • 1015 Answers
SOURCE: draft fan comes on glow
It sounds to me like your gas valve is bad. If you can get induced draft motor to come on then Hot surface ignitor to come on the next step should be lighting burner. I would check to verify that you have fuel to unit and if you do I would reccomend you get a new gas valve. Hope this helps. Thanks
Posted on Nov 22, 2010
Samsung Gas Dryer model DV328AGW/XAA, not getting gas to ignighter,
Could be a defective igniter, thermocouple, or gas valve
Mar 06, 2017 | Samsung Dryers
KENMORE GAS STOVE OVEN , how to check if power is coming to the ignitor
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Sep 07, 2014 | Kenmore 24 in. Gas Self-Clean Single Wall...
Kenmore gas oven 326b1016p001
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 03, 2014 | Kenmore Ovens
Oven starts and stops
Apr 02, 2014 | Kenmore Ovens
No gas to oven
Mar 01, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ignitor work but burner do not lite
Feb 16, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
If oven igniter is not getting power what is the cause. Oven is plugged in. Broiler igniter works.
Feb 04, 2014 | Kenmore Ovens
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
Whirlpool Gas Dryer
Yes, that is most likely the problem. Once the glow bar igniter glows so hot, the switch opens & drops power to the igniter.(The radiant sensor has continuity while cold & open when a flame is present.) At the same time, by opening it redirects power to the valve coils allowing them to open & gas flow to the burner assembly. The dying glow of the igniter fires the gas. However, if your igniter glows, the radiant sensor is good. In this case, you'd need to replace the gas valve solenoids.
Aug 01, 2007 | Whirlpool LGR5644J Gas Dryer
Heating & Cooling Logo
64 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
