Question about Whirlpool RBS305PDS Electric Single Oven
The oven will not get hot
There is power to the oven but the oven will not get hot
I will change the ignitor out on the unit.
Posted on Feb 23, 2014
Whirlpool oven will only get to 250 degrees, help
250' Centigrade is full power, Gas Mark 9, 482' Fahrenheit
This is an approximate conversion chart between gas mark and electric ovens. This information was copied from the rec.food.cooking FAQ.
Gas Mark Fahrenheit Celsius Description 1/4 225 110 Very cool/very slow 1/2 250 130 --- 1 275 140 cool 2 300 150 --- 3 325 170 very moderate 4 350 180 moderate 5 375 190 --- 6 400 200 moderately hot 7 425 220 hot 8 450 230 --- 9 475 240 very hot
Sep 24, 2015 | Whirlpool Ovens
Oven door won't open and oven buttons don't work
It might be possibly locked because it is in self-cleaning mode.
Mar 17, 2015 | Ovens
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
Troubleshooting frigidaire oven
Too hot of a temperature - Check RTD sensor probe and replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive
Sep 03, 2012 | Frigidaire Ovens
The oven is not getting to temperature
Check the breakers/fuses that supply the power to the oven. It sounds like it is not getting enough power.
Jun 16, 2010 | Whirlpool AKZ159IX Oven
Have an oven i need to replace I blieeve it is 4 wires at the back of the oven with no external venting. The opening is large enough for a 27 or 30 inch oven. Is it as simple as pullout the old one...
if its electric its hard wired to your home power 220v black(hot 120v) white(neutral) red(hot 120v) green (ground) You should wire the new oven the same way as the old oven (Shut off power before any thing)Make all wire conections clean and tight with a wire nut. wrap each with ele tape.
Dec 23, 2009 | Ovens
I have a Kenmore 9114012190 oven it does not heat properly anymore the top and lower elements get hot but it will hardly get anything warm that is placed in it ie; bread has to stay in it for 45 mins to...
start by checking your input power for a full 240volts,then check the terminal block for any burned off power input wires,then check power connections all the way thru the oven control and finally check for "hot-spots" in both elements(highly unlikely that both would be bad) its a discolored area that is a high resistance area not passing full operating power thru element(s)
Nov 19, 2009 | Kenmore 40192 / 40199 Electric Single Oven
THE OVEN WILL NOT HEAT
How old is the unit? Sometimes the igniter can glow but if it isn't drawing the right amount of power to open the gas valve then that is the safety that is built into the oven... So unless the power requirement is meant gas valve will not light. Even though the hot surface igniter is glowing red hot. chances are the igniter is bad. Let me know what turns up. ken
Dec 03, 2008 | Magic Chef 9112 Gas Double Oven
Whirlpool RBS305PDS Electric Single Oven Logo
51 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
