Question about Mitsubishi WS-55809 55" Rear Projection Television
Bad Lamp for TV
I have a 6 year old Mitsubishi WD-52531 and the picture is getting dark. I ordered a replacement lamp #915043010, installed it as directed and closed the rear panel. When I plugged it in, I saw the flashing green timer light and then the lamp light came on as red/orange. Was the replacement DOA, the old lamp still works when reinstalled.
Can't get a reception with my ws-a55 tv
Posted on Feb 27, 2014
Slinteriors
  • 8617 Answers
SOURCE: WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Posted on Sep 04, 2008
SOURCE: No picture and no sound after replace lamp for Mitsubishi WD-51525
I was having the same issue after a lamp replacement and the warranty tech said that it was the lamp power supply that went out. The part was on back order and look at the board neaqr the lamp and it had a blown capacitor. This would make since why the lamp would come on then shut off right away. She replaced the capacitor and works fine.
Posted on Jan 02, 2009
ladywinn
  • 5138 Answers
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Posted on Sep 27, 2009
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Posted on Oct 31, 2009
Testimonial: "no wonder you are an expert, we are nothing without you. huge thanks"
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
No picture
Lamp life for this model is 2 years or 2000 hours, less if a non Mitsubishi lamp is used, sounds like a bad lamp.
Dec 22, 2012 | Mitsubishi WD-52531 Television
The lamp light is blinking orange and we just replaced the lamp! on model WD-52531
You may have not plugged the lamp in fully or have not put the lamp door back properly. If you have done this properly and have the blinking problem then you are likely to have a bad ballast. This ballast supplies the voltage to light up the lamp. But first look on the front of the set for a small push button that says "system restore/reset". Use a ball point pen to press.
Jun 28, 2011 | Mitsubishi WD-52531 Television
Picture is very dark
its probably the lamp going bad. dark picture is a pre-cursor to failure. these lamps are supposed to last 2-4 years but for some reason the mitsubishi ones never do. you can replace the lamp yourself, and if it is going bad, you can cool it down, pull it out, and you will see it will look kind of bulged or white in the bulb part. instructions are in your user manual. if it is under a year old, mitsubishi should still cover it. if its just over a year, you can try to call them and complain and maybe they'll back it up. let me know if you need further assistance.
Jun 06, 2010 | Mitsubishi WD-65735 Television
I have a Mitsubishi big screen. the lamp went out and i installed the new one. it worked about a day or so. then i couldn't turn it on anymore. lamp button blinks and no picture. i took out new lamp and it...
Where did you get the lamp? Did it look like original part? If not, you need to get your money back. There are a few out there selling replacement lamps that are just cheap knock-offs.
May 19, 2010 | Mitsubishi WD-52531 Television
Mitsubishi WD-52531 not working after replacing the buld.
Check to make sure the lamp is in correctly and that you've closed everything up properly. If you don't close the cover, the sensors will tell the computer in the TV that the door is open and won't let the TV turn on.
Other than that, could be a bad lamp or bad ballast.
Always buy OEM lamps, or better-than-oem equivalents! Philips lighting is the best lamp manufacturer out there for these TVs. They invented the thing!
Buy from Authorized distributors, and don't buy the "cheap" stuff. savnig 20 bucks will cost you more in the long run--believe me!
Feb 05, 2010 | Mitsubishi WD-52531 Television
Jul 18, 2009 | Mitsubishi WD-52531 Television
Same problem with Mits WD-52531
The first thing to try is to reclose the access door to the lamp area. There are interlocks there that may be marginally connected. Try to reclose all access doors and report the results here.
Thanks,
Dan
Jun 29, 2009 | Mitsubishi WD-52531 Television
Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
