Dishwasher light says it is locked - Computers & Internet
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
Dishwasher wont turn on when I press start and... the "3 second" lock light is constantly on??
Child Lock Controls
To prevent children from accidently changing the
dishwasher cycle or starting the dishwasher, lock the
dishwasher controls by pressing and releasing the RINSE
ONLY pad (some models) or the NO HEAT DRY pad (some
models) for 3 seconds while the door is latched. An
indicator light on the lock graphic pad will illuminate when
the controls are locked and no new selections can be made
until the lock is released. To unlock the controls, press the
same pad, RINSE ONLY or NO HEAT DRY, again for 2
seoncds until the indicator light goes out.
Hope this helps?
Mar 31, 2016 | Frigidaire FFBD2406NW Built-In Dishwasher...
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
The lock symbol light is on and the dishwasher won't start
the DELAY START pad (some models) or the AIR
DRY pad (some models) for 3 seconds. An
To unlock the controls, press the DELAY START
pad or AIR DRY pad until the indicator light goes
out
Nov 21, 2010 | Frigidaire PLD4555RFC Dishwasher
Child proof lock light is on, cannot run the dishwasher
To turn off the Child Lock
Press and hold ENERGY SAVER DRY for 4 seconds. The
light turns off.
Apr 18, 2010 | KitchenAid 24 in. KUDM25SH Built-in...
Dishwasher won't work heat lock light on how do
some dishwashers have a "lock out" mode so kids don't accidentally turn on. Normally, by pressing and holding the button for 5 seconds, it should turn it off.
Apr 07, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Lock light is on
The lock only locks the buttons (childproof), hold it 3 seconds and it will go out.
Jan 18, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Lock Light Blinking
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
Jan 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher locked key has been activated.
To turn on Lock:
Press and hold Heat Dry for at least 4 seconds. The Locked light
glows. If you press any pad while your dishwasher is locked, the
To turn off Lock:
Press and hold Heat Dry for at least 4 seconds. The Control Lock
light turns off.
Dec 18, 2008 | Whirlpool Dishwashers
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
