Question about Beko Washing Machines
Beko wma 745 w error h - Beko Washing Machines
4 Suggested Answers
SOURCE: Beko WMA 1715S
try unplugging and let it reset itself
Posted on Apr 03, 2008
FitzOriginal
  • 842 Answers
SOURCE: beko wma 1510s keeps tripping eletric sockets
I once had a machine that would trip the power if it had an unbalanced load when it went to spin. Whirrr.... bang bang bang bang... click! Lights out.
HOWEVER, this is highly unusual. If the machine is tripping the power then you should take great care. either you have an electrical fault (The motor may be failing and burning out, or another component may be failing unsafe) or you may have a water leak from a defective hose somewhere that is getting electrical equipment wet. Just remember that water and electricity are a very un-funny mix and your trips are there for a good reason.
Does the machine trip the power as soon as it is powered on, even after standing for days (Probably an electrical fault)? Does it trip as a particular thing happens, such as moments after the water coming into the machine or as the drum starts to agitate or the spin cycle starts or as the water empties.
Here are a few suggestions. Having thought about when the fault trips the power, do the following:
TURN OFF THE POWER AND UNPLUG THE MACHINE FROM THE WALL. Isolate the water supply. Make sure that the machine is drained of water. Now it's safe, look for water leaks.
Take the top off the machine (Usually a couple of screws in the back and then the lid will tap forward or pull back depending on the model). Look for signs of water inside the chassis, where the water pipes run from the inlet valve to the soap tray. The rubber gasket around the door may also be cracked and leaking. A classic point for the start of a leak is the rear bearing of the drum (This is the centre of the big wheel of the drum), you may see water marks or limescale buildup that has dripped from the bearing if it is leaking.
If you are looking underneath for leaks, never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
While the machine is on its back, look at the motor, If you can, have a good sniff at it (Do you smell burned electrical equipment?) Look around for other components such as printed circuit boards, visually inspect and sniff them too.
The golden rule here is if you can see a leak and you can replace the part, then that's great, go ahead and Do It Yourself. BUT be sure that when you have finished everything is absolutely dry inside (Use a hairdryer if needs be). When you are absolutely sure it is all safe then prepare to test. With everything connected up turn on the mains and start the machine. ONLY TOUCH THE PLASTICS until you are sure it is working exactly as it should. Even then you should of course check to ensure that there is no electrical power leakage. If in doubt, it the power trips, if you have the slightest concern, get a professional in, Your family will prefer to pay for his visit rather than your funeral.
Posted on Feb 09, 2009
SOURCE: Beko eco care WMA 10W: The washing is always very
eko eco care wma10w is making loud noise when on full spin, have looked at belt seems to be fine
Posted on Dec 05, 2010
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
What is error code E3 in washing machine Beko 91242 LC
This error code is below. Good luck to you:
E3
Constant heat
Nov 25, 2014 | Beko Washing Machines
BEKO eco care WMA W10, replaced brushes still wont wash or spin,pls help
Hi if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Apr 08, 2013 | Beko Washing Machines
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 26, 2013 | Beko Washing Machines
My beko wma 510 has just flooded my kitchen and wont do a full spin or drain
Hi kelly if your beko wma 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Feb 17, 2011 | Washing Machines
I need to buy the instruction booklet for the beko WMA 620 W washing machine.
This is the link where you can download user manual for BEKO-WMA 620 WASHING MACHINE
http://www.2instructions.com/results_mm.php?materiel=Washing%20Machine&marque=BEKO
hope this helps you,thank you
Feb 08, 2011 | Washing Machines
Nov 19, 2009 | Washing Machines
Beko WMA 1715S
Apr 03, 2008 | Washing Machines
Fault code or engineers reset for beko washing machine wma 756s serial no 05-100 905-06
please can you send me fault code for beko wma 665 w serial no 05-103296-10 thankyou
Dec 21, 2007 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
