Question about Canon MG6150 Printer
Pixma 6150 mac address - Canon MG6150 Printer
My canon pixma 6150 does print on both sides of paper but the second/back side is upside down so I cannot make booklet
select long side flip rather than short side flip for an A4 booklet. An A5 booklet should be set for short side flip.
Feb 03, 2017 | Canon PIXMA Office Equipment & Supplies
Pixma MG7750 wireless with MacBookpro OK, with iMac not working printer off line or not connected
Check your IP addressess. Apparently Mac machines change their Mac addresses whenever they find a new network, but may not remember the previous settings.
Jan 11, 2017 | Canon PIXMA Office Equipment & Supplies
How do I get my canon ip6000 printer to recognize my Mac computer
You need to go on your mac and download the driver and install it on your mac.
https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/ip-series/pixma-ip6000d
Assuming printer only has UBS interface Mac should recognise the printer is connected to it once you install the driver .
If it has an internet protocol ip address tcp/IP then give printer an ip address in the range of the MAC and it will be detected by the mac.
Dec 17, 2016 | Canon Office Equipment & Supplies
Printer canon pixma mp495 multifunctional
Since you've already performed a Factory Reset, which ought to take care of anything along the lines of corrupted system files, you might want to double-check that you have the correct drivers. Canon Support Drivers PIXMA MP495
Once you have the correct drivers, try doing a factory reset on your printer while it is not connected to your computer. Once complete, try using the USB cable that came with your printer to connect it to your laptop and install the drivers.
There is the possibility that your printer, even after a factory reset, is trying to automatically use WiFi for its connection to your laptop. Assuming you're using DHCP and not static IP addresses, try giving your printer a static IP address, as it may be fighting with some other LAN device for a particular IP address.
If it turns out you do have the correct drivers and you are using WiFi for the laptop to printer connection, I would suspect something is wrong with the WiFi connection on your printer's side or in your router's configuration. Make sure you have the printer's MAC address in the appropriate table in your router's filtering configuration, if you're running MAC address filtering.
Apr 06, 2014 | Computers & Internet
Poor print on my Canon pixma 6150
1. try the deep head cleaning 2. check the content of the cartridge3. be sure that you are using a new cartridge before executing the deep clean4. then print the alignment page 5. after printing the alignment page 6. scan the page on the scanner
Nov 01, 2011 | Office Equipment & Supplies
Canon pixma 6150, Poor prints, missing text every few lines. Have done self clean. Printer is only two months old.
pls check the ink level and be sure it is all full and try to clean the clogged head deep cleaning then test print you can choose on the printing preferences
Finding mac address
To check the MAC address of the machine, use the up or down arrow buttons to display Setup on the HOME screen and press the right FUNCTION button,
then go to Device Settings > LAN Settings > Confirm LAN settings > WLAN setting list to see your MAC address details. YOu should see a screen that looks something like this:
WLAN setting list
MAC address
Printer name
Bonjour service name
May 29, 2011 | Canon Pixma MG6120 InkJet Printer
Cant seem to get the download needed for the installation process for my ESP 6150
Try this page: http://support.en.kodak.com/app/answers/detail/a_id/36460/kw/esp%206150/selected/true
Keep in mind, you may need to browse around Kodak's support site more if this is not the right driver page. Drivers are written specifically for your operating system. Each version of Windows will have a different driver to download, or if you have a MAC you will need to get the driver for your version of OSX.
Good Luck
May 26, 2011 | Kodak 6150 AllInOne InkJet Printer
Pixma IP 4200 does not print
On the first question it sounds like the Mac might have a problem with its port. Check cable, try another device in that port. You really should ask around on a Mac site as this is not a printer problem since it works on another machine.
For the second person, you're using the machine plugged into a network? Is it plugged into router? If you're having an IP address conflict, you can get the problems you're describing. Make sure that you use a static IP address that is much higher address than any dynamic machines might be assigned.
For example, if you're using dynamic IPs, for example in the area of 192.168.1.100 and up. If you have four OTHER devices on your network, they may be 192.168.1.101, .102, .103, .104. So, the highest IP address they should be assigned is 192.168.1.104. Too allow for guest IP addresses, you should set your printer to be 192.168.1.109 so none of your devices or a guests device will ever be able to have a conflicting address.
Sep 21, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MG6150 Printer Logo
24 people viewed this question
old marine
old marine
