Question about Denon Audio Players & Recorders
Denon dcd 7 5E
My cd player denon model 7.5E is erroneously connected with power supply of 220 volt a.c ispite of 100 volt a.c now the transformer is burnt but only 100 volt winding burnt . now i want to to replace it can i replace it here in pakistan witha transformer having in primary 220 volt and in secondry i does not know how many volt be required to operate the syestem if you help me intelling that how much volt and current required for operation of this player. this player
  • Paul Bade Jun 12, 2017
    Hi GHULAM MUSTAFA, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Can you still read the label on the transformer? Sometimes the secondary voltages and current ratings are provided on it.
  • 11 Answers
SOURCE: How do I replace a damaged power supply transformer on a DN-600F ?
Hello there. i'll suggest you one quick solution but it maybe dangerous!(Do it the greek way :P) try to remove the transformer from the machine. Take one Ohm meter and measure the resistance of the 120 vac coil. IF THERE IS NOT ANY (i mean that the ohm meter shows nothing diferent than not using it) get a paper blade and start removing the paper cover that it has rounded from the place where the 120 vac wires goes. you will see there that there is a mini thermal fuse.short circuit the thermal fuse and try to measure again the resistance of the 120 vac coil. if you see something between 40 and 80 ohms you are ok. Now that you haven't got any thermal fuse on your transformer just increase your security putting on a 300 mA fuse at the 120vac coil. I have done it with many hard to find transformers and it worked for me.Just be sure that when you plug it on, you will not touch it because i don't know if you are gonna do it right.ok? (say ok!) That was the second solution to your problem. The first and the safest is to go to your local dealer and order a new transformer.
Posted on Aug 10, 2007
  • 112 Answers
SOURCE: power transformer problem
You need the service manual for those values. A quick google search shows it costs more than the replacement transformer!
But that is for the 110v version @$21. The same company sells the service manual @$24 or just keep googling.
Posted on Jan 25, 2008
SOURCE: Denon CD player DCD 920. When using the
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Posted on Oct 14, 2009
  • 910 Answers
SOURCE: I accidentally plug my aiwa excelia cd player
If you're lucky you'll have just blown the internal fuse.
You need to remove the cover and look for the little glass fuse on the PCB where the power cord comes in. If it has blown then look at the metal cap on the end of the fuse and is should tell you what rating it is (2A etc). You should also check to see if any other components appear damaged before replacing the fuse.
Posted on May 03, 2011
SOURCE: have a Denon DCD-520 and it skips forward and back while playing
I have had a similar problem with my Denon DCD-520, the laser current needed adjusting with a watchmakers screw driver, try turning it a quarter clockwise turn and see if the problem is fixed.
Posted on Aug 17, 2012
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
I want the correct valves for C-105 and R-100 , R-103 for my denon cd player dcd-f100.
Dear lovin4sha,
The correct valves for the specified components are :
C-105 ------- 22 mfd 100 v
R-103 ------- 3.3 K 1/5 watt
Enjoy bye.
Jun 04, 2011 | Denon DVD-F100 DVD Player
Will it be okay to connect a 110 volt laptop to a 220 volt LCD projector?
What voltage is your mains supply?
The laptop's adapter should be a multi-voltage type 110 to 240 volts input.
If your mains is 110 volts AC then the 220 volt AC LCD projector won't work unless you connect it to a step up transformer (110 to 220 volt transformer).
If your mains supply is 220 or 240 volts then both the laptop and the LCD projector will work without any problems.
Aug 24, 2010 | Computers & Internet
Denon Amp (PMA-700AE) ignores the signal from CD Player DCD-700
If you can follow the circuit from the input of the cd play socket inside the amp itself you might come accross a Memory Retention Capacitor that supplies an IC. If you do. I can't for certain say one will be there, I would replace it, it might be the cause of the lost memory of your device.
If you don't know what a M R C looks like, they are like electrolytic types, but haven the appearance of being squashed. The value will be low only 0.22uf etc and the volts very low say 5.5. The PC board marking will be different to a normal capictor.
Nov 14, 2009 | Audio Players & Recorders
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
Having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Apr 15, 2007 | Denon DCD-425 CD Player
51 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
