How do you get the right time to stay after you
How do you get the right time to stay after you fix the time on a plastic BEZEL 1308
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 86 Answers
Glue gun?
Posted on Feb 20, 2014
How do i set my time on my plastic bezel 1011 watch from walmart
I have a Plastic Bezel Watch 1504 ; How do I set the time and allow it to count down and give accurate time . Please and Thank you
Sep 22, 2011 | Watches
Replace tailgate handle 2002 avalanche
If it's similar to a Silverado, the tailgate handle consists of a bezel (plastic cover) and a Red and Green plastic clip that break very easily. Take the bezel off (just pull carefully from the tailgate, careful not to break the plastic clips) look for 2 rods, again 1 connects to a red clip, the other to a Green, replace the broken one, or a cheap/temporary fix is to use a plastic zip tie at the connection. Snap the bezel back in.
Jan 23, 2011 | 2005 Chevrolet Avalanche
How to change the time
I had the same problem with my 01 Optima. Sometimes you can change the time, but most of the time nothing happens when you push the buttons. I don't really know what fixed it, other than I removed it, cleaned the plastic face with polish, and reassembled it into the bezel. Now it works perfectly. The bezel is held to the dash with snaps, no screws, so it comes of easily. I used a hook type screwdriver, like the ones that are used for installing springs. I carefully inserted the tool between the lower left corner of the radio and the bezel, rotated it a quarter turn toward the bezel, and pulled straight ot with maybe 10 or 15 pounds of force. It's pretty strong. Next unclip the 4 or so electrical connectors on the back of the bezel. They each have the "squeeze to release" tabs on one side. Use a good #2 phillips to remove the clock, mine was super tightly screwed in. Maybe thats why it works now? good luck!
Jan 03, 2010 | 2001 Kia Optima
Replace LCD screen
No, Remove the Screws On the Front Bezel Of the Screen.. (there should be 4 One on each corner), Then you will need a thin plastic tool such as a guitar pick or thin credit card... Pry the front plastic bezel from the back cover starting at the top right corner.. THe Whole Front Bezel Is Held On By Snap Down Plastic Tabs... You Will Need To Slide The Plastic Tool Along The Entire Top Of The Screen At an Angle... Then Once the top is insnapped, Do the sides, Then The Bottom.. Front Bezel Is Now Off And You Should Have Full Access To The Display...
You will have to Unscrew the screen from the Hinges On THe Left And Right Sides... Usually 2 or 4 screws on each side then screen is removable
Nov 17, 2009 | Acer Computers & Internet
How do I remove the invertor from a Qosmio F20?
The inverter is located behind the bezel at the bottom of the screen/lid and in between the hinges.
The bezel has screws that fixes it to the lid and these can be hidden by stick-on plastic covers. Use a thin sharp point to lift these plastic covers off to reveal the screws. Remove these screws.
The bezel has small plastic catches that clips it to the lid and may also be fixed to the LCD screen with double sided tape. Use a thin blade and insert it between the LCD screen and the bezel and gently ease the bezel off. Start at the bottom of the screen and gradually work along the edge and continue around each side to free the bezel.
Be CAREFUL not to scratch the LCD screen and DO NOT apply too much pressure to the face of the LCD screen because you can crack the glass surface and ruin the LCD screen.
Once the bezel is removed then you can get access to the inverter to remove it.
Nov 16, 2009 | Toshiba Qosmio G15 Notebook
Citizen watch bezel does not stay in place.
If you've been trying to snap on that bezel and it does not stay in place, you probably lost the bezel fixing spring.
Find your nearest watchmaker and ask to sort things out.
Dec 17, 2008 | Watches
My watch keeps beeping!
Sounds like you need to lock the bezel, because it is always active and will change even with accidental brushing against body or clothes. Choose the screen yuo want to display and press the two buttons on the side at the same time and your bezel should lock. A brief message will appear onscreen. Do the same to unlock. With the bezel locked you can start and stop the session timer as usual using the start/stop button at top right.
Dec 12, 2008 | Garmin Forerunner 405 Handheld GPS...
Need instructions to replace the bezel on a gateway 7330gz
Just like any other laptop LCD screen, edtechservic. Remove the rubber caps that cover the Philips head screws, remove the screws, and work around the bezel to pop it loose, a little at a time.
Top cover up, you are looking at the LCD screen. Look at the top Left and Right corners of the screen bezel. Look in-between. Now look along the bottom of the screen bezel. See those small rubber caps? G-E-N-T-L-Y pry them loose with a 60 or 90 degree pick. (In your computer repair kit)
Use care, and finesse! You don't want to scratch the clients laptop!
Now loosen, and remove the screws underneath.
Use a Jewelers flat tip screwdriver, (No.2), and ease it in the parting line, that you will see between the bezel, and top cover. Don't go more than a 1/4 inch in! You could be up against the LCD screen metal frame, if you go too far in. (Which could break the LCD screen)
Won't ease in there? Move over an inch or so. You could be hitting the plastic part of the bezel, that snaps down into the Top Cover.
There are several of these plastic protrusions, that stick down from the bezel, and snap into place in the Top Cover. Every few inches or so.
After you start easing one of these plastic snaps out, (Plastic protrusion I spoke of above), move along the edge, pick another place, and start easing it up. Keep bringing the edge up a little at a time. (Bring the back of the flat tip jewelers screwdriver down)
When you have gone along, and raised a large portion of the bezel, you should hear a distinct Click, as one of the plastic snaps come out of the Top Cover.
If not, move back to the first plastic snap that started to come out, and place your flat tip Jewelers screwdriver next to it. Bring the back of the screwdriver down to pop that plastic snap up, and out.
Hearing it your first time might make you a little stomach sick. You'll think you broke something! If you go along, and raise the bezel up a little at a time, you'll be okay. The bezel is made of space age plastic, and is VERY tough! You can't get crazy with it though!
When you have gone almost all the way around the bezel, the last few inches may just pop up, and out.
This link shows you with photos, and information, for a Gateway MT6704 Notebook PC,
http://www.insidemylaptop.com/remove-lcd-screen-from-gateway-mt6704-model-ma7/
This guide is to completely replace the LCD screen. You can just use the information under the first five photos, for bezel replacement.
Nov 15, 2008 | Acer Aspire 3000 Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
