Question about Sewing Machines
Janome 415 manual
I've been sewing oilcloth and at first the Teflon foot wasn't working right as was making loads of little stitches and going a million miles and hour yet not going anywhere, I've since changed the foot and everything was running smoothly until the machine started to get slower and slower until it eventually just stopped? Any ideas? Machine only two weeks old
    Guru:
  • 377 Answers
Https://drive.google.com/file/d/0B5HhTHUdm3VxbVY4TVAtamF0VUE/edit?usp=sharing
you can download this file hope that it will help
Posted on Feb 15, 2014
  • 69 Answers
SOURCE: Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Posted on Feb 09, 2009
  • 136 Answers
SOURCE: I've lost my manual for my Janome 415 sewing
know of no place to download, can order from linssewvac@hotmail.com
Posted on Sep 08, 2009
bargainbox
  • 1388 Answers
SOURCE: New Janome 6600 Erroring out
This is the official Janome reference to your E% error message:
Feed sensor error "E 5" appears when the machine is turned backwords slightly while the machine runs over tight spot. The above will happen when - the machine is locked by thread jammed in the machine. - sewing extreamly thick fabric. In case of the MC4900, it will happen when running without threading the thread take up lever. The thread take up lever should be threaded when the threading light lights up.
Hioe this helps
Bargain Box
Posted on Jan 02, 2010
SOURCE: Pfaff 1471 will not run. Thanks to gherna1 for
Have the same problem. Did you ever find a solution
Posted on Oct 03, 2010
SOURCE: My sewing machine will not stitch, it is threaded right
how do you crrect the timing on a yamata 811
Posted on Dec 20, 2010
I have a Janome 11000SE and when I sew a hem on a cotton garment it is bunching. The thread seems to be tight, even though it works well on other cotton matterial. Can you help me please?
Make your stitch length longer and loosen your tension a little..You could also use some tissue paper under the fabric to stop it from catching. I have a teflon foot that works well too. You didn't say what kind of cotton, 100% or a blend so try what I suggested.
Feb 04, 2018 | Janome Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
New home Janome 2039 sewing machine
if these suggestions don't help then the machine needs to be
checked for a timing problem
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 29, 2013 | Janome Harmony 2039 Mechanical Sewing...
Where can i get a presser foot for a Janome 1017
Sep 18, 2012 | Janome Harmony 1017 Sewing Machine
Can you sew leather or vinyl on Husqvarna 415? If so, what tension, needle and foot should I use?
Ok. Depending on the thickness... garment weight leathers can be sewn with a domestic machine... Most often an even feed foot (the home version of a walking foot) is needed. You will likely need a larger leather needle and somewhat longer stitches than you would normally sew.
As for stitches looking messy on the back that is a top tension problem... you'll need to tighten the tension until that goes away. AFTER you have made sure you have your machine threaded correctly with the presser foot in the up position.
Aug 19, 2012 | Husqvarna Freesia 415
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Jul 16, 2011 | Sewing Machines
My needle breaks 2 in a row
Don't pull your fabric as you seam as this is a sure fire way to break needles.
Also, make sure you have got the right foot on it for the stitch sequence it is sewing. For example, don't use a foot with a little hole in it when doing a zig zag as the needle will strike the foot. The general purpose clear plastic foot is usually a good one for most stitching.
If you are trying to sew something pretty heavy then this can cause breakages too as the machine may struggle to pierce through 6 layers of denim when you cross another seam. For example, hemming jeans, when you stitch over the side seams, your machine is trying to pierce probably 7 layers, the leg, plus the felled seam turned twice. It will struggle. You can help it by using a "Jeans-a-jig" a little plastic device you hold in front to get the foot up over the lump and give it grip. But take it really slow and sew one stitch at a time.
Jun 08, 2011 | Janome 1600P-DB Mechanical Sewing Machine
What settings for doing zig zag for satin stitch around applique. I have used 3.5 width and 0.2 length but the fabric has a tendancy to pucker and the stitches sometimes bunch
It depends on a couple of things. Depending on the fabric you're using you might want to use a stabilizer like an iron on tear away. If the stitches are bunching the stitch length might be to tight. Try going to 0.3. if the stabilizer doesn't work. With the stabilizer on, it will keep the fabric firmer so it won't pucker. Make sure you have the decorative stitching foot on the machine with the little indentation for the satin stitch to ride in. If you have the wrong foot on, this will cause bunching too. Let me know if this helps.
Aug 22, 2010 | Janome Memory Craft 4900QC Mechanical...
How do I turn corners with the overlock foot for a Janome 2049?
Sew to the end of the fabric, slowing right down to within a stitch or two of the end, manually turn wheel to complete last two stitches, stop, raise needle, raise presser foot, turn fabric so the back edge of the fabric is just under the needle, drop needle, drop presser foot and resume.
Mar 13, 2010 | Janome 2049LX Mechanical Sewing Machine
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
