Question about Alarm Remote Casecover Accord Odyssey 02 03 04
Honda keyfob reset - Alarm Remote Casecover Accord Odyssey 02 03 04
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
Ingition switch on -> press lock
Ingition switch off -> on -> press lock
As fast as u can on the fifth cycle the car will lock
program is complete
Posted on Jul 16, 2015
Key fob not working
save $100 at the dealer. Ready ..Make sure u have new batteries or batteries are ok. Put key into ignition. now press keyfob anf hold while turning key to on position and count to 30 seconds still holding keyfob button then turnback to left and remove key from ignition. this will reset your keyfob and reprogram your security system. You will also know when your batteries are getting low by your red and green lights wherever their located. When they start blinking 3 times in a row its a sign your batteries are getting low... good luck. hope it helps..
Feb 01, 2014 | 2001 Mercedes-Benz ML 320
2009 honda civic hybrid
May be keyfob needs reprogramming to make it work line normal.
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There is a related troubleshooting link mentioned below for remote key fob reprogramming. Click the link below to go through its details and procedure: -------
ANTITHEFT WILL NOT LET CAR TO START?
http://alltypesofpartsreplacing.blogspot.com/2012/12/keyfob-programming-reprogramming-car.html
These will help.
Thanks.
Dec 10, 2012 | 2009 Honda Civic
My my honda accored tourer tailgate will not open both manually or power assisted
My Honda Accord 2004 tailgate would not open with keyfob or manually, tailgate light on dashboard on. Took it to Honda in Colchester expecting large bill but they fixed it quickly by disconnecting battery for 30 secs - with ignition key removed (important). Reconnected battery, put ignition key in, dashboard lights cycled, then opened tailgate by hand. Checked it's not sticking. Then used keyfob and it works! No problems since. Apparentlly it's a cold weather thing. No charge - full marks to Honda's Glynn Hopkins of Colchester.
May 15, 2012 | Honda CR-V Cars & Trucks
I had to put a new battery in my remote that I use to unlock the doors on my 2002 xtype Jaguar. Since changing the battery I can not get it to operate. How do I reset it?
http://www.bluejag.co.uk/X-Type-keyfob-reprogramming.php
copy/pasted from the above link..
"Programming or pairing a new remote Keyfob for the X Type is a very simple job that will cost a substantial amount if it is done by Jaguar. It's annoying but this may need to be done if your Keyfob battery has been allowed to go flat, or the car battery has been removed for any length of time.
Follow these steps exactly and you should have no problems, pairing old or replacement Keyfobs for your car.
1.)I would recommended that you ensure all key fobs are fitted with new batteries. ( Click here to see battery replacement guide).
2.)Get in the car and close the drivers side door.
3.)Put the key into the ignition and turn to position I.
4.)Wait 5 seconds
5.)Turn the key quickly to position II then back to I four times.
6.)You should hear a single chime.
7.)Remove the Key
8.)For each Keyfob in rapid succesion. Press any single button on the keyfob you wish to pair, you should hear a chime as each Keyfob is paired with the security system. After the chime do the next Keyfob.
9.)Check operation of each Keyfob. "
Hope it works for you!
Sep 21, 2011 | 2002 Jaguar X-Type
I haven't driven my 2000 Honda CRV in about a week. When I tried to unlock it this morning neither of the remotes would work. I can get into the car manually unlocking the doors but the engine won't...
It sound like the keyfob remotes turn your alarm off on the vehicle. The starter disable part of the alarm is preventing you from starting your car. You will have to get your remotes fixed. Might just need batteries...
Oct 08, 2010 | 2000 Honda CR-V
Honda Pilot KeyFob
It takes CR1616 3volt
Dec 14, 2009 | 2009 Honda Pilot
Batteries in keyfob are dead got new ones,how do you reset for a citreon saxo
From what I understand of the RSA Secure log on is that when the unit goes "dead", the connection to the server is lost. In order to restore the connection you will have to call a Helpdesk and have them refresh the server to "find" your keyfob.
Dec 08, 2009 | RSA Security RSA SecurID Keyfobs Full...
Codealarm keyfob on 2005 Mustang not locking/unlocking doors.
Try this http://m.wikihow.com/Reset-a-Factory-Car-Alarm g
Nov 20, 2009 | Code-Alarm Code Alarm Transponder
Panic alarm after using the jumper cable how to stop making noise
this is a protection feature to prevent disabling the alarm, if you have no means of stopping it with a keyfob, then disconnect the battery ground and reconnect it, that usually resets stuff to where you need it. check your manual first and make sure that I am not giving you wrong info on your battery as some are hooked up weird and have buttons and clips to get to do this stuff. (AKA BE CAREFUL!)
Aug 16, 2009 | 2006 Honda Odyssey
Alarm Remote Casecover  Accord Odyssey 02 03 04 Logo
69 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Mike Carew
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
