Question about Microsoft Xbox Console
How to program pelican blade 2.4 remote - Microsoft Xbox Console
How do I program my key fob to a 94 Olds 98 regency?
Assuming it's a standard GM half moon style key fob, you can get replacements soon many sources including dealerships, locksmiths, and ebay.
Programming depends on whether you already have a working key?
If you don't, you will have to go to a dealer or find a locksmith who has the right equipment (I suspect not many do).
THis works for Holden Commodores of that era, most GM products should be similar:
If you have a working key, it's relatively straight forward, as the car can program new keys.
1 remove screws holding key blades into the remote heads of both keys.
2 remote the key blade from the *new* key and put aside.
3 insert old (working) key into ignition and start the car.
4 with car running, carefully slide the remote head off the key in the ignition barrel. Car should stay running.
5 carefully slide new remote head onto the old key blade sitting in ignition. Make sure the metal contact inside the key blade insert makes contact with the key blade. Make certain the small contact pin on the facing edge of the remote makes contact with the metal slide ring on the outside of the ignition barrel - these two contacts form a circuit.
6 The key fob should program almost immediately, but leave the fob in position for 30 secs to a minute to ensure its done.
7 turn car off and reassemble keys.
8 test all functions of new key - remote entry and engine start.
(get key blank cut by a locksmith before commencing the above!)
Feb 09, 2015 | Cars & Trucks
Pelican 7060 flashlight manual
FlashMax G179 - Waterproof CREE LED Flashlight
Adding the particular FlashMax G179 water-proof, powerful DIRECTED Flashlight. This kind of torchlight will be one thing to seriously acquire anxious about. It really is really potent. Remarkably resilient. Water-proof. And also makes use of Cree LED's, and that means you realize you'll get white colored mild together with decades regarding program using this attentively developed Flashmax DIRECTED Flashlight.
Apr 17, 2012 | Pelican 7060 LED
Need a front seat
1. Contact Pelican and try to buy one from them.
2. (What I would do) Go to a local shop that actually works on canoes. Get a wooden seat from them that is cut to the length you need to fit your canoe.
Jul 21, 2011 | Boating
How do i link the pelican remote to the xbox 360?
There should be several USB ports on your 360. There should be one in the back and two in the front lower part of the console. It is hidden beneath a small flap you can push in with your fingers and slide the cable into the usb
Apr 10, 2010 | Pelikan PELICAN PL-3601 Xbox 360(TM) TSZ...
I have a old xbox system and my wireless controllers by pelican brand pl-2050 one will not link up to the xbox what to do!!
Check to verify that your batteries are installed correctly.
- Check to verify that the power is on. Check to verify that the signal LED is blinking
If this does not solve the problem, do the following:
1. Make sure your Xbox is turned off.
2. Remove the battery lid and place 2 AA batteries into the Blade 2.4 Street Wireless Controller. Make sure the batteries are inserted as shown in the battery compartment.
3. Insert the receiver into your Xbox controller slot of your choice and power up the controller FIRST, then your Xbox.
4. Press the Connect button on the receiver once. Your signal LED light will begin to flash slowly.
5. Press the Back button on your controller. This will program the receiver to connect to the controller each time it is uses.
6. Turn on your Xbox and insert a game.
Aug 06, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
I just bought a wireless remote control for my xbox and i cant get it to work?
There is a little white buttom on your xbox , this is the sync buttom , on your remote there is a small round white buttom too ( sync buttom again ) press those 2 and it will find your new controller
Jan 26, 2009 | Pelican XBOX CONTROLLER WIRELESS- SPIRIT...
Wii DDR mats
I may be posting this a bit prematurely, but if you go to www.pdp.com, I believe you can get an adapter for the Wii for free. I know that the pad plugs directly into the Game Cube port, so I don't know what this will actually adapt until I install it (it's been about 10 days and I haven't got it yet).
Note: If you can't find where to get the adapter from the PDP website, go to your local Walmart, find the box, and there are stickers now on the box pointing to the website you need to go to. Note that there is a phone number, but it will do nothing other than tell you to go online.
Good luck to all. I would love to see a post confirming this Fixya.
Nov 02, 2008 | Konami Dance Dance Revolution Hottest...
How to attatch 7" Pelican Game Glass to slim Ps2
Slim PS2s have to holes on back left and right. The far edges one lower right hand side of the power plug and another on the upper left side of the fan exhaust. Hard not to notice. I've never actually noticed they were screw holes I figured they were just... holes. Hope this helps.
- Xero Necross
Dec 26, 2007 | Sony PlayStation 2 Slimline Console
Microsoft Xbox Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
