Every time I broadcast the picture is zoomed in. Help!!!
    Habit-Forming:
  • 152 Answers
Please check the zoom settings in view ( browser )try to set to default else reset the browser its works fine.
Posted on Feb 17, 2014
Where do I go to have my full screen.
You are stuck with the broadcast aspect ratios whatever they might be. All you can do I zoom in but that distorts the image and you lose clarity and it cuts off part of the picture, use the Widescreen mode for best over all picture..
Jan 20, 2017 | Televison & Video
I can not get full screen on all channes
Some programs broadcast the picture that way and the only way to make it full is to select the stretch or zoom feature but even if you are on full screen if they dont broadcast it that way it will not be a full picture.
Jan 25, 2015 | Olevia 237T 37 in. LCD TV
White stripe on screen
Unfortunately it seems that each time I turn the tv on and off it resets the screen position and I have to adjust it each time.
I would assume that my set would remember the settings.
Use Picture Size, not Picture fit. Set it to 16:9, instead of Fit To Screen. There's a handy button the the remote for this: P-Size. And the setting sticks between shut-offs.
What you are seeing is called "overscan", extra information that most broadcast stations send, because most old TV's were set to zoom-in/crop the signal they received. So.. with new TVs, like your Samsung, you get the choice between size "Fit to Screen" which is 1-to-1, for pixel-accurate inputs like Blu-Ray and DVD, and size "16:9" which is really "support for overscan", for old, less precise signals like broadcast.
Mustang Parts.
May 28, 2012 | Samsung Televison & Video
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Just recently my sharp aquos lc 40 e is stuck in stretch of wide screen and the heads or top of things are being cut off. When i go to view mode it only gives me 4 options wide, stretch dot to dot or zoom...
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
Aug 29, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I just bought a new insignia LCD TV and the picture does not cover the entire screen. Instead of the 32 inch. diagnal I should, I have a 24 inch picture. Is there something I can do about it?
The "picture size" on the TV needs to be set correctly. You should have a "ZOOM" button on your remote. Press it a few times, cycling through the options... see if this fixes the problem.
Be advised, many (most) HD channels do not show HD content all the time. At the broadcasters discretion, they may choose to ADD the black bars to either side (and/or top an bottom) of the image. This is what the "ZOOM" button is actually for... to allow you to correct this, filling the screen with the image.
*Note: many cable box have a "FORMAT" or "HD ZOOM" button. When used in conjunction with the TVs zoom feature, you can end up having one device set correctly, while the other is not. The result is often a picture that is expanded far beyond the bounds of the displayable area of the screen. If you can not find a solution using the "ZOOM" button, pick the setting which shows the most image. Now adjust the cable box setting (FORMAT / HD ZOOM).
Mar 06, 2011 | Insignia Televison & Video
How do I get the picture to fill the screen instead of having all that black space on the sides?
Using one of the older antennas on an hdtv when receiving broadcast channels can cause that.
It might just be the channel you are on. You should have a wide button or aspect, format, zoom or view mode on the television remote to adjust the picture size.
If you have a cable box or satellite tv receiver you can try the hd zoom #, aspect or format button on it to adjust the picture size.
You might be connected to your cable box two different ways and you may be on the wrong input
The program you are viewing may only be broadcast that way
Oct 28, 2010 | LG Televison & Video
Gray bars on side of picture
Yes. There are options. Strech, wide, full, zoom, and gray bar are common options. Some times when aa HD channel is not broadcasting in HD you will also get a narrow picture.
Apr 30, 2010 | LG 42LG50 42 in. LCD HDTV
Image cut off of Samsung LCD TV picture
if you have a time warner remote press the # to zoom
cox has another button . don't know it. ask them.
Mar 08, 2008 | Samsung LN-T4671F 46 in. LCD Television
Cannot fill screen with normal picture size setting
assuming you all have comcast and using an hdmi cable
first access menu (hit it twice) and go to set picture format, choose passthrough....or in your case auto hdmi
then turn box off, press guide and info on the front of the box, proceed through the setup, advanced is more in depth..lol...
select 1080, 720, and then either the standard or widescreen 480s to your liking.....
voila....
now check your tv settings to accommodate
Nov 17, 2007 | Sony BRAVIA KDL-40V3000 Television
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
