Question about Ingersoll Air Tools & Compressors
Ingersoll rand unigy manual - Ingersoll Air Tools & Compressors
  • 1383 Answers
SOURCE: manual
Ingersoll rand parts and manuals are available at www.grainger.com, or call you local grainger store, they have a very good customer service for faxing parts lists to your place. Notice: some Ingersoll rand compressors have been recalled. Check the address below. If you have general questons about a problem that you are having, post again. Good Luck
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02108.html
Posted on Jan 10, 2009
  • 98 Answers
SOURCE: Ingersoll Rand DS 35 Service Manual?
Call I.R.
Posted on Jul 21, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 41 Answers
SOURCE: I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Posted on Sep 28, 2009
Testimonial: "Cool!!Thanks!I finally got a "page" on pressure switch. Its not in the regular owners manual. It was like pulling teeth,& had to get it from GRAINGER"
  • 17 Answers
SOURCE: I am looking fo a manual for ingersoll rand t-30
http://company.ingersollrand.com/Pages/default.aspx
Posted on Dec 31, 2009
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Impact wrench manual
You can download manuals and parts lists from Ingersoll Rand.
Follow this link:
Ingersoll Rand Industrial Technologies On line Publications
Feb 23, 2014 | Ingersoll Rand Air Impact Wrench 1in Dr...
Diagram of parts
you can download ingersoll rand tool manuals and parts lists from
www.irtechpubs.com
Jan 22, 2012 | Ingersoll Rand 1/2" Super Duty Air Impact...
We have an Ingersol Rand Unigy IRN-11-8-H with software upgrade increasing current to 21.9 amps and 1.70 cubic meters/min. It has the option switch selecting ramp-up or down or just standard off and on...
Unfortunately, that drive is pretty well "cleansed". I-R is not like many compressor manufacturers who use a standard Siemens or Allen Bradley drive. They use something obscure and modify it so that you can't get outside support. You will have to go to a IR distributor.
As a side note, the Unigy series was plagued with problems. They had a 120% failure rate, meaning on average that each one failed more than once during the warranty period.
Mar 14, 2011 | Ingersoll Air Tools & Compressors
We have ingersoll rand VSD compressor Unigy L AR model IRN11K-10-500-H, the machine has got brake down due to some electrical fault and the technician reported that there is an electronic drive failure and...
These VFD or VSD units do experience drive failures. If it is not covered under warranty it will be and expensive repair. You might try calling the IR Phone # that should be affixed to the unit. Some times they might recommend replacing an electronic board and supply it to you. Other than that replace the drive.
Jan 15, 2011 | Ingersoll Rand Compressors 5-HP,...
Where may I purchase or download a complte repair manual for the Ingersoll Rand model # 2475N7.5? Thank you in advance, Gary
I would suggest contacting a local Ingersoll-Rand air center, a lot of times they can make you a copy for little or no charge
Dec 28, 2009 | Ingersoll Rand - Rand Type - 30...
Manual
Jan 09, 2009 | Ingersoll Air Tools & Compressors
Air Tools & Compressors Logo
406 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
