Question about Pyle PLMCA61BT Bluetooth Motorcycle Speaker Kit - plmca62bt
Installing pyle motorcycle speakers on handlebars
Need handle bar speaker install instructions
5 Suggested Answers
technical114
  • 1851 Answers
SOURCE: What is the best way
The PLMRA400 is ready for either 4- or 8-ohm speakers, in pair. This means that the distortion that you hear is not due to the connection. I suggest to take a closer look at these points:
  • If you inter-change the speakers, the distorted sound stays at the same speaker or at the same channel?
  • Use only the speaker (or channel) with the disrtorted sound. Is the distortion still existing? If no, the problem is not at the amp - speaker, it's at the power supply (battery?). At high volumes the amplifier needs more power (current) from the battery.
  • What is the source that you drive the amp with? Do you use the high level inputs or the RCA connectors?
The case of having problem just one of the amplifier's channel is very rare, that's why I suggest to make sure that no other problem is existing.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 27, 2011
dunnbiker
  • 8546 Answers
SOURCE: I am thinking about purchasing
Any search engine will lead you to details about the speakers.
http://www.pyleaudio.com/itemdetail.asp?model=PCB3BK
They're passive mini cube speakers. Unless your unidentified CD player has amplifiers and connections for speakers you are missing the crucial middle piece. What were you going to do about bass?
Posted on Aug 12, 2011
gopakumarg43
  • 74482 Answers
SOURCE: Pyle PDWR68B speaker has an internal speaker loose
Buy one speaker. You can bought it from any electronic spare part selling shops.
Posted on Jun 03, 2012
  • 256 Answers
SOURCE: install pyle radio in 1996 monte carlo
Get the proper dash kit end wireing harness adapter kit, That plugs into the factory radio wireing harness, That is the easist way to do it,
Posted on Dec 04, 2012
Right speaker not working
You may have a better chance with this query if you post it in a forum dealing with motorised sports equipment.
Aug 27, 2016 | Pyle PLMCS36 400 Watts...
How to install, since it doesn't come with instructions.
Unless your speakers / boxes are specific for your car, there will not be any installation instructions beyond generalized that may include a wiring diagram, a chart to show how much volume your speaker box needs (minimum and optimum), power handling, etc.
Search for your model / part numbers at Pyle Car Audio and see what information is available there.
Sep 18, 2010 | Pyle Car Audio & Video
I want to install a speaker system to the handlebars. Can/should the wiring be routed under the gas tank? If so how is the tank removed?
Just a suggestion,no offense.I'd check out how much of the frame top rail that the tanks mount to.you have access to.Drill a hole in the front that will allow you to access the handle bars with speaker wire.Drill another hole in the end,under the seat front.You'd only have to remove seat.Fish the wire thru the frame rail and connect each end to where you want.Places that install sound systems can give you stiff wire to fish with.Check out this possibility before you remove tanks.On the plus side less exposed wires on frame.
Feb 01, 2010 | 2008 Harley Davidson FLHRC Road King...
I am trying to install Z Bar handle Bars on my Harley Davidson. I need install instructions on how to thread the wires.
I assume you are talking about running the wiring internal of the new handlebars and you need to know how to pull the wires through the them. You need to get a "fish tape" through the bars. The easiest way to get the fish tape into the bars is to start off by getting a string through them.
Use a shop vacuum and connect it to one end of the bars. Plug the other end of the bars temporarily. Turn on the vacuum cleaner and feed a string in from the hole in the center of the bars. If the bars are not too rough on the inside, the string will be sucked out the end of the bars.
Once you get the string through the bars, form a loop on the end of a scrap piece of wire and use the string to pull it through the bars. Now, use the wire to pull the switch wiring through the handlebar.
You may want to put some type of "sleeving" over the switch wiring so that you don't skin the insulation off the wires as you pull them through the handlebars.
Good Luck!!
Oct 30, 2009 | 2004 Harley Davidson VRSCA V-Rod
Can I install 4" kickback riser under the handlebar
Just make sure the cables are not binding or too short.
Replacing the risers are pretty straight forward.
Remove the four hold down bolts then remove the stock risers. Towel will help here to prevent handle bars from scratching the tank. Helps to have the front wheel straight before starting this process. Install the new risers using the hardware supplied. Be sure to check clutch and throttle for binding BEFORE riding.
If they bind and prevent easy operation you may have to purchase extension cables. Be sure to torque the 4 bolts that hold down the handle bars properly. After a few trips check and tighten again to the proper torque settings. Installed the Baron kick back risers on my 1100 and it took a few trips to get use too.
After that wouldn't take anything for them! Sitting higher and not all slumped over. Nice looking too!
Hope this Helps!
May 28, 2009 | 2007 Yamaha V Star Custom
Need install help on Pyle PWLB12D speakers
you will need to take old ones out and cut to stock connector off and wire the new one in
May 02, 2009 | Car Audio & Video
Installing handlegrips
Not sure on the Harley but on dirt bikes and atvs I blow air in the ends and they come right off.Go on the same way.
Dec 25, 2008 | 2003 Harley Davidson FLHR Road king
Pyle PLMCA61BT Bluetooth Motorcycle Speaker Kit - plmca62bt Logo
55 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
