Question about Lexmark C533DN InkJet Printer
Refilled both colour and black cartridges Solid C light.. flashing B light...
Just finished refilling both colour and black cartridges Solid C light flashing B light...Software says both are still empty
eagle338
  • 4889 Answers
SOURCE: Refilled color cartridge for lexmark Z845
The only work around to this is to use two catridges(2 color and 2 black and white). The reason is the printer has a mechanism to check if the same catridge is being used again. SO when you have two cartridges when one is finished refill the other and use and vice-versa. This way you will be able to refill and use for ever without any problems..
Regards,
Eagle338.
Posted on Mar 13, 2008
  • 52 Answers
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Posted on May 05, 2009
  • 744 Answers
SOURCE: refilling cartridges
Joe,
You should have received control program software with your printer. If installed, the icon should be on your desktop or it may be in your programs list. You can also get the software from the Lexmark web site.
Anyway, you probably need to reset the cartridge using the control program. It's not difficult. Just follow the prompts.
Posted on May 16, 2009
mstipps
  • 16 Answers
For that printer: there are 4 color and 4 black cartridges BESIDES the #31 photo cartridge. Lexmark has made it so you MUST either, throw away or send to them, the 36 and 37, the 36XL and 37XL. The printer will never again recognize them after they are removed from the printer...
However, the 36XLA and 37XLA AND the 36A and 37A as well as the 31 Photo may be removed from the printer, refilled, and reinstalled.
I have seen some forums that say you can but a piece of BLACK tape, across the bottom row of contacts on the non-refillable cartridges....I believe there are 4 to 7 contacts across the bottom row only.....and the printer will still give you a message that it needs ink.....but it WILL print. I have not tested this theory yet though. I have just gotten the first message saying my black ink is very low.
Hope this helps and I think Lexmark Corporation Sucks for tricking people like this. (This printer comes with the NON refillable cartridges as default, but I did NOT see in the documentation that it couldn't be refilled. Nasty people........:(
Good Luck~~! mstipps@yahoo.com
Posted on Jul 07, 2009
  • 6 Answers
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Posted on Sep 29, 2009
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
After refilling he black an coloured cartridge, i always get the error E 5 and the lights B and C are flashing orange. I already changed the cartridges several times.
Using refills and non-canon inks can cause issues with the printer. You can damage the print head and fill up the waste ink tank faster then needed..
Best of luck..
Dec 03, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Just changed cartridges to refills and clour and black lights flashinghowever we can still print ok. Why are the lights flashing?
The lights are flashing because you are using refilled cartridges. The printer "sees" those cartridges as empty, since it can not know that someone has refilled them. When you put in new cartridges, the lights will stop flashing.
Just ignore the lights and print!
Hope that helps!
May 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
You can't refill these cartridges yourself. Your printer remembers the serial numbers encoded in the electronics of the cartridges that have been in the printer. If your printer sees the same serial number in a row it will kick out the cartridge. HP printers don't use this same system to reject cartridges. I recommend Cartridge World refills or refills from anywhere that has a high turnover of these cartridges so you don't get one with the same serial number.
May 27, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My printer wont print black colour on pics or word docs
Hi, sounds like a dodgy ink cartridge. I would purchase a new black cartridge and fit and try that. Refilling epson cartridges isn't a good idea, if you can't afford originals, but compats instead of refilling them. a good place to buy is www.choicestationery.com I've never had any problems with their carts.
Dec 14, 2008 | Epson Stylus Multifunction Inkjet Printer/...
How to use only black when the color is finished
you cannot use the printer by just keeping only 1 cartridge in the printer.as both the cartridges should be present in the printer then let the colour cartridge is empty what the problem is.you can print the black printouts with empty colour cartridge in the printer, but both the cartridges should be in the printer.and if still you get the message as colour cartridge is empty please replace the colour cartridge.the simple option is yopu can get the same cartridge refilled.as the cost of refilling is 10 times less then the new cartridge.
Oct 03, 2008 | HP PSC 750 All-In-One InkJet Printer
Working with cannon ip 1300
You need to have a black and a color cartridge installed to use your printer. That doesn't mean the color cartridge has to be full. You can have an empty color cartridge in the printer and it will work as long as the electronics are good on it so the printer can recognize it's there. You cannot refill these cartridges yourself. Your printer remembers what cartridges have been in it so that it can reject refills (it sees the same serial number twice and catches you trying to not give Canon their money). You can use refills, but you need to get them from a refiller with a high turnover of cartridges so you don't get the same serial number twice. I recommend Cartridge World stores as they have high quality refills with a 100% satisfaction guarantee.
Sep 21, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
I have just put in both black and colour refills into my printer which is a Pixma MP150, it it printing both black and colour ok, however my Black Ink light still keeps flashing on and off, the coloured...
I think you printer cartridge as sensor which ink levels as it is failed in the black cartridge ,you can either clean the contacts the printer and cart with dry tissue paper and replace and set printer installing new cart or use it like this because the printer company doe not support refilled cartridges to be used .
Apr 09, 2008 | Lexmark X1240 All-In-One InkJet Printer
Regards,
Eagle338.
Mar 13, 2008 | Lexmark Z845 InkJet Printer
Lexmark z845 ink refill problem
eagle338
Rank:wizard_s.gif Wiz
Rating: 79%, 740 votes
Regards,
Eagle338.
Jan 16, 2008 | Lexmark Z845 InkJet Printer
Lexmark C533DN InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
