Bush tv problems
Good Afternoon My tv switched it's self off and when I put it back on there's a white information line across the top which keeps running through all the scart connection devices available and all the free-view channels available. I can't set it to any device i.e, HMDI or manage to set it to any channel. I have had it switched off and unplugged for a week and have just connected it up again, but the problem is still there. Thank you Heid
  • 4402 Answers
SOURCE: white horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Posted on Dec 03, 2007
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
  • 60 Answers
SOURCE: Samsung LN-T5281F TV: Control panel on TV is not responding
  1. Need to replace the main Board
Posted on Aug 23, 2009
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
SOURCE: cant connect playstation 2 to LG lcd tv
I have a sony bravia lcd digital color tv. I want to know how to plug in my play station 2? The PS2 has a coaxial cable running from it with a side coaxial connection. Where an how do i connect?
Posted on Oct 15, 2010
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
Bush tv keeps switching itself on and off standby
I think that the problem of your tv is only the switch. Is this always happening when watching the tv specially when the tv is producing vibration because of the sounds? Try to set your tv in mute and observe the duration of the fault then put some sound and observe again if the duration will change. Feel free to send feed back good day.
Aug 08, 2011 | Bush Televison & Video
I am trying to help my neighbor. She has a Sanyo flat screen tv Model DS20930. The picture she gets is a thin line across the center of the screen.
Set the brightness, contrast and colour control of that TV to minimum. Watch it in a dark room whether ther are thin white lines across the screen, at about an inch apart, from bottom to top of the screen. If there are lines, that TV needs screen control adjustments. That is, now the screen voltage given to the picture tube went high to some reasons. If you have confidence that you can adjust it, I will guide you.
Open the back cover of that TV. Locate the LOT [Line output Transformer], usually one red thick wire is connected to the top of the picture tube with the help of a rubber ****** and clip. In most TVs it can be located and can be seen as the back cover opened. There are two variable control, fitted, integrated to LOT. Normally the upper one is marked as focus, and the lower one is marked as screen. You shoud adjust this control to avoid these lines.
It is a live service, that is the TV must be switched on during this time, and take causion in every respect not hurt by yoursef and the TV. Keep the children away from you, and an other adult person beside you is better. A liitle turn counterclockwise will remove this problem.
Oct 19, 2010 | Sanyo DS20930 20" TV
Cooling problem
more than likely its the field output ic or caps around that stage
using hairdryer and freezer spray you can narrow down the faulty component
best of luck.
Sep 07, 2009 | Toshiba Televison & Video
Thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Jan 17, 2009 | Televison & Video
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
