Question about Janome Sewing Machines
How do I remove rust from my sewing mache - Janome Sewing Machines
    Champion:
  • 276 Answers
For rust on body visit auto parts store for rust converter, this product does what it says and stops it. for rust discolouration on shiny components like presser feet etc brass and silver polish work but any brown spicy sauce condiment is as good and costs pennies
Posted on Feb 20, 2014
How do you thread mach
you have only put,how do you thread mach?
so i think this is what you are asking.
try this link.
How to Thread Sewing Machine
Dec 16, 2016 | Sewing Machines
I have a Singer Touch and Sew #758. The bobbin case keeps popping out of possition when I try to sew. I have cleaned and oiled the machine, checked all the threading, tried different bobbins, etc. The...
it does sound as if the sprung bracket is not holding the case in position. Move the latch to the right, remove and install the case and then move the retainer back into its proper position
Feb 17, 2014 | Singer Drop-In Bobbin 758B-28BH Mechanical...
My sewing maching sews a little and than skips
Make sure all lint is cleaned from the needle and bobbin area. Rethread machine change needle and try sewing again
Nov 29, 2011 | White Sewing 1632 Mechanical Sewing...
How do I replace the needle in a Brother CS-100 sewing maching?
Go to www.brother-usa.com and under support pick home sewing group, then select your model, cs 100t and download a free manual. It will show you where the screw is located, do not remove the screw, just loosen it.
Apr 17, 2011 | Brother CS-100-T Computerized Sewing...
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
I keep getting a prompt that states that my usb calbe is not pluged in.... futura 100 singer emboridery sewing mach. the mach. is pluged in and ive loaded the software several times. still the same thing.
Make sure you're plugging the USB cable from the machine into a USB port in the BACK of your computer, not one of the front ports or a port on a USB hub. The cable and machine need more power than most of those ports provide, a technical detail that Singer doesn't realize. Good luck!
Oct 26, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Mar 17, 2009 | Singer 7462 Mechanical Sewing Machine
Timing on a brother sewing maching LX-1120
The timing is set on the lower shaft on the left end. Needle bar rise is 2.5mm. Check your timing belt tension to prevent this in the future.
Jan 25, 2009 | Brother LS-2125 Mechanical Sewing Machine
I am trying to start sewing using the brother SE-2700 machine and it keeps giving me The safety device has been activated error message. I have done everything in the manual that it says to do to fix this...
Hello
Make sure the bobbying is lettinng out the string first and also make sure the dial on the left side of machine is on 6 .when you turn the maching around , looking at the back make sure switch in too your right. Also just unplug the maching could help, my wife just had the same problem...
Jan 21, 2009 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
