Bush tv problems
Good Afternoon My tv switched it's self off and when I put it back on there's a white information line across the top which keeps running through all the scart connection devices available and all the free-view channels available. I can't set it to any device i.e, HMDI or manage to set it to any channel. I have had it switched off and unplugged for a week and have just connected it up again, but the problem is still there. Thank you Heidi
techman
  • 3130 Answers
SOURCE: Several dozen thin horizontal white lines across the top of screen, all channels
These beasts are monsters to get into and service without the proper extenstion cables and a service manual. there are no user replaceable parts inside this set. if you know solid state serviceing, you can try and fix it. There is a bad capacitor or capacitors in the vertical sweep circuit and or the vertical output IC is bad also. If you can solder and unsolder go for it. But if you do not or know how the circuit Works Please find a trained tech to assist you with this repair. Good Luck. PS please do not forget to rate this.
Posted on Oct 14, 2006
SOURCE: how do i connect my 360 to run on HDTV to a bush lcd tv?
Have you set the settings in the dashboard to HDTV as well as changing the switch on the RGB cable? (The switch is on the end of the cord that plugs into the xbox).
Posted on Apr 26, 2007
SOURCE: Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Posted on Jan 15, 2008
Midwest-tech
  • 243 Answers
SOURCE: my tv keeps changing the channels on its own
take out the batteries of all the remotes that are able to change the channel and put a piece of duct tape over the infared reciever and if it still does it, it is most likely defective.
thanks,
Nate
Posted on Aug 22, 2008
SOURCE: How to unlock TV channels if I forget the password
My TV Is Locked So How do I unlock those TV
Posted on Jan 09, 2009
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
Bush tv keeps switching itself on and off standby
I think that the problem of your tv is only the switch. Is this always happening when watching the tv specially when the tv is producing vibration because of the sounds? Try to set your tv in mute and observe the duration of the fault then put some sound and observe again if the duration will change. Feel free to send feed back good day.
Aug 08, 2011 | Bush Televison & Video
I am trying to help my neighbor. She has a Sanyo flat screen tv Model DS20930. The picture she gets is a thin line across the center of the screen.
Hello
Set the brightness, contrast and colour control of that TV to minimum. Watch it in a dark room whether ther are thin white lines across the screen, at about an inch apart, from bottom to top of the screen. If there are lines, that TV needs screen control adjustments. That is, now the screen voltage given to the picture tube went high to some reasons. If you have confidence that you can adjust it, I will guide you.
Open the back cover of that TV. Locate the LOT [Line output Transformer], usually one red thick wire is connected to the top of the picture tube with the help of a rubber ****** and clip. In most TVs it can be located and can be seen as the back cover opened. There are two variable control, fitted, integrated to LOT. Normally the upper one is marked as focus, and the lower one is marked as screen. You shoud adjust this control to avoid these lines.
It is a live service, that is the TV must be switched on during this time, and take causion in every respect not hurt by yoursef and the TV. Keep the children away from you, and an other adult person beside you is better. A liitle turn counterclockwise will remove this problem.
Oct 19, 2010 | Sanyo DS20930 20" TV
Cooling problem
more than likely its the field output ic or caps around that stage
using hairdryer and freezer spray you can narrow down the faulty component
best of luck.
Sep 07, 2009 | Toshiba Televison & Video
Thin white horizontal lines across top of TV
replace vertical out put ic and related capacitors
please refer to a qualified tv personal to check tv
Jan 17, 2009 | Televison & Video
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
