Question about Sony BRAVIA KLV-37S310A LCD TV
My Sony tv model KLV-375310A LCD had a problem with the electronic cards
Electronic card failds
melnavz
  • 1226 Answers
SOURCE: Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Posted on Apr 08, 2008
SOURCE: SONY KLV-40U100M LCD TV will not power up. looking
by going to people that are true helpers and not looking for the almighty dollar...............
Posted on Oct 27, 2009
Testimonial: "I believe !!!!!!!!!!!!!1"
welcomejee
  • 10594 Answers
SOURCE: 8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Posted on Feb 09, 2010
leusnerdus
  • 54 Answers
SOURCE: looking for a sony bravia klv-46x350a lcd spare
Usually the LCD panel cost is around 80% of total TV price. Look for it in a center of service.
Posted on Apr 20, 2010
SOURCE: Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
hi i have a sony bravia ex710 .dont power on .and leds lcd 5 star
Posted on Jan 24, 2013
How can i fix str for sony tv/klv-19t400a?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 18, 2016 | Sony KLV-19T400A 19 inch Multi-System LCD...
Ido not understand how bt tv actually connects to my tv
Hello Mate
Is your KLV-32U300A have PCMCIA Card so you can connects easily your BT Tv. but if your TV don`t have that slot so sorry dear you have to upgrade your Tv. And I am surpizse that model is almost 4 to 5 years old, And its still works. (Nop its don`t have the PCMCIA CARD SLTS). Share with me you BT TV model or Device #.
Dec 11, 2014 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Sony bravia KLV-32S550A when i turn on tv green light(POWER LED) flashes red for 60 seconds on and off after total power shutdown. pl tell me what a problem
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 02, 2013 | Sony KLV-32S550A 32 inch Multi-System LCD...
My 2 years old Sony LCD TV (model # KLV-32S400A), while it was working, went OFF (no picture and sound), refer the trouble shooting manual, switch OFF and ON again found in stand by mode LED was blinking 8...
Ask the dealer because this kind of repairs should be must warranty on hidden defects, a television is made for a lasting time between 4 and 6 years then yes lead free solderings and are they reliable ???
Its very strange that SONY is having in between 2 years a defect.
Its much to early for a real Sony .it was no old refurbished second hand or a forgotten older model ?
Very Important is this is to realize in case of trust was it the intention of the technician to sell you a new t-con or a refurbished one ? thats should in many cases the weak point if you look on that refurbished board that exact the same problem with the same ic could happens then for shure there is a hidden defect. its easy to see where was repaired on the board.
The replace of the lcd panel is maybe guesswork on the fcc cable connection sheets it should only to be replaced if there where vertical lines somewhere
If no warranty is give on hidden defects by the dealer write to Sony A solid complaint.
The dealer is the first contact let them inform a representative of Sony regarding this complaint, the four-year minimum healt of your tv was not reached, you as a customer is entitled to a good product that is expected at least four years. warranty on parts wages in leniency possible but not required.
Questioned about that dealer: are they commercial boxes sliders or solid proffesionals where you just pay and get service without having to smoke a cigar from your own box
SONY KLV 26S400A KLV 32S400A KLV 37S400A CHASSIS EG1L GA EXPLODED WIEV NO...
Mar 26, 2017 | Televison & Video
What is the remote code for this tv Sony KLV-S32lA10
Hello
Programmable code number for DVD/VCR [Sony] is _ 601 (Sony Dream System)
Programmable code for SAT/CABLE is _ 801 (Sony Satellite Receiver)
Above stated both codes are common for [SONY KLV-S19A10 _ KLV-S26A10 - KLV-S23A10 AND KLV-S32A10 compactable]. OK.
Feb 24, 2011 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Hi i have a problem with sony 40" lcd and model no KLV-V40/A10 that lcd is not coming on , it only blinks the indicator 6 to 8 times and stops in stand by. Pls help me out in this...
Although I'm not familiar with that particular TV, it's sounds like it could be a problem with the power supply board, which is a common problem with many HDTV's. Specifically, look for faulty electrolytic capacitors on the power supply board. Faulty as in: discolored label from heat, bulging, exploded, or all of the above.
Hope this helps!
Feb 13, 2011 | Sony Televison & Video
Confused between lcd's!!!
All LCD,Plasma tvs these day are very similar designs and qualities,but don't buy unknown brands,because when u require boards for defective tvs that require electronics boards replacement.Better chance to find refurbishes pcb boards.If u have name brand tvs models.U like the LG model,think it better buy the LG models.
Jun 15, 2010 | LG 32LD450 32 In. LCD HDTV
REPLACEMENT LCD PANEL
Have a look here I have the same problem and have been looking for 3 days...I hope this helps as I have tried the service manual and the part number is...1-805-870-21...with no luck...http://www.invertercentral.com/qrySpecSheet.asp?page=srlp&name=LTA320W2-L02&number=LTA320W2-L02&title=Toshiba&Country=Australia
Nov 21, 2007 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony BRAVIA KLV-37S310A LCD TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
