Question about DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi pac 26nswitches off if the water container is inserted
jfpogie
  • 104 Answers
SOURCE: DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Posted on Jan 20, 2008
22yooper
  • 828 Answers
SOURCE: Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
Posted on May 21, 2008
SOURCE: delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Posted on Sep 06, 2008
SOURCE: Empty wateron DeLonghi Pinguino Pac L 90
That probably is Ft, meaning full tank. Look on the bottom of the back side, and there should be a small "hatch" that will open. The two small hoses in there are drain hoses that can be unplugged to drain the tank. They're right at the bottom, so if you have a way to raise the unit up a little that would let you drain the water into a container. Might be a good time to clean the filter too.
Posted on Sep 19, 2008
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
My water container has black fungus ,Icould'nt clean it and I'm afraid to use it.
get a filter from repeatable store.. if i may where's one i recently bought one works good.
Water Treatment
Jul 17, 2016 | DeLonghi Pinguino PAC-700T Air Conditioner
How to remove water tank of delonghi P AC W130 portable air conditioner
OWNERS MANUAL for DELONHI
PAC W130
http://www.delonghi.com/Global/InstructionManuals/GB/GB-5751018800.pdf
Oct 29, 2013 | DeLonghi PAC W130 Portable Air Conditioner
DELONGHI PERFECTA SAYS INSERT GROUNDS CONTAINER WHEN IT'S ALREADY INSERTED
Just had the same problem after washing my ESAM5500.
Seems that some water hot on the switch that is triggered when grounds container is inserted.
My solution was removing the bottom panel (5 screws if I remember correctly) and disconnect the green wire from the switch (there are three wires - green, ping and blue). When the green wire is disconnected, coffee maker thinks that grouns container is inserted all the time - even if it is removed.
Jul 30, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi air conditioner it has a triangle with an exclamation point inside. What does this mean?
There is a knob on the back and bottom of the air conditioner. Twist off the knob and unplug the little black plug and empty the water into a container. I had the same problem and this worked for me.
Jul 17, 2012 | DeLonghi PAC W130 Portable Air Conditioner
Leaking
Please check the water container for leaks. Normally,
it does not leak, since the water is supposed to evapo-
rate due to compressor heat. The water that the aircon produces goes to a containing pond near the compressor. So that if there is a leak, it emanate from
this area. May this tip help you.
Jan 10, 2010 | DeLonghi PAC C100 Air Conditioner
Regarding the delongi pac 50 is it vital to have water constantly in the machine when it is on? if it is on and there is no water in the container will it burn the machine out?
The water in the machine comes from the cooling coil, and is condensate. This happens with all cooling systems. And no, no water in the cup will not burn the machine up.
Please reply if you are having problems with the unit.
Dec 17, 2009 | DeLonghi Pinguino PAC-77E Air Conditioner
How do we get rid of the water that collects in
There is no container, it burns it up inside into hot air and sends the moisture out the exhaust tube which you hooked up to the back of the unit and ran either outside or underneath house through flooring. There is one of these units that does come with a bucket in the front bottom drawer that comes out, but if its a PAC ct90 just like mine, there is no water empty it handles all that itself.
Aug 04, 2009 | DeLonghi PAC T110P Portable Air...
Sep 08, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi pac-02 a/c
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Emptying Water
open the big front door, pull the top of the water container toward you, take it out turn it over, unscrew the top, pour out the water
Jul 23, 2008 | DeLonghi Pinguino PAC-210 Air Conditioner
DeLonghi Pinguino PAC-02 Air Conditioner Logo
23 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
