Question about Panasonic Drills
RILL IS BEAPING WHEN YOU PULL THE TRIGGER - Panasonic Drills
  • Panasonic Master
  • 1,885 Answers
Giving 2 short beaps and 2 red leds on it blinked .
If its a EY7440 ? the control pcb must be the problem itself , but if its a brushless model then the 6 mosfets on the motor could be short circuit EY754* was oft the cause, but they have modified the motor for the new EY75** models with brushless motors .
RILL IS BEAPING WHEN YOU PULL THE TRIGGER - rill-beaping-when-pull-trigger-mhucwgdeevnzvqxh2vgvynmt-4-2.jpg
Posted on Oct 18, 2015
How do i adjust the trigger pull
Very carefully as if you get it wrong
Most rifles come with limited adjustment to the trigger pull down to 5lbs if you are lucky so to get them lighter say to 2.5lbs final stage you either have to get a after market trigger or
Stone the surfaces of the trigger but doing this is very very dangerous if you make a mistake
Take the weapon out of the action and look at the trigger for small screws or Allen bolts that adjust the sear engagement and if the trigger has them adjust them a little bit and test trigger pull and safety catch to see if it dry fires when you operate the safety if every thing goes OK repeat until you get desired pull weight or run out of adjustment then think about a professional trigger job as if you get it wrong you will start putting rounds in unexpected places
I have gone on about getting it wrong a lot as I have seen weapons with truly hidious trigger jobs that have fired by closing the bolt or setting the safety to safe which has given the other shooters a nasty surprise and the poor nut on the gun a shock
Jun 09, 2015 | Miscellaneous
450 trx for Wheeler just got it and it don't electric start but it will pull start and he sed the values needed shined or adjusted jut try to find some rill in put
I have requested more info, but am guessing the starter motor may need to be removed, cleaned (sometimes get a lot of dirt & oil inside) , maybe new brushes. Or,have a look at the solenoid connection and make sure the wire is still connected to the starter motor. I dont know the extent of your mechanical knowledge, but there should be a power wire and a solenoid wire to the starter.
Mar 02, 2014 | Motorcycles
I need to adjust my trigger pull on a Ruger Model 77 rifle.
If you'll look up into the trigger assembly inside the trigger guard you'll see a set screw. I've got one of those old Rugers and supposedly that set screw is for adjusting trigger pull wt.
Nov 07, 2012 | Refrigerators
How does the framing nailer work with a black button grey button
Dewalt has two triggers available for their framing nailer. The black trigger (390746-00) is a bump style trigger. While holding the trigger, you will be able to fire a nail by pressing nose against work. This trigger is preferred by most framers because it is much faster. Gray trigger will only allow one nail to be fired. Bumping will not work with the gray trigger. With trigger released, you must place the nose against work then pull trigger to fire. To fire next round, you must release trigger, pull gun off the work, again place nose against work then press trigger. Check dewalt web site for recall information. Some dewalt framers have been recalled for faulty trigger. Good luck with your projects.
Aug 11, 2011 | Dewalt Round Head Framing Nailer D51845
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
Leakingaround oil filter
if you have just changed the filtre make sure the old sealing ring is off 2rings will cause it to leak
Oct 07, 2010 | 2005 Dodge Grand Caravan
I can't get it started and I"m following directions on side of machine.
Those direction are not accurate all the time, I usually prime mine 4-6 times. put mine on full choke with the trigger pressed and pull 1 time any more will usually flood it, If you have the choke that kicks off after you press the trigger, put the choke back on to half and pull the cord pressing the trigger, Then pull the cord until it starts without pressing the trigger. As before if you press and hold the trigger during the start it will flood these trimmers..This should start the trimmer. You may have to let the trimmer set for about 15 min if it was flooded.
Sep 19, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a Generac XL4000. It rill start but not run right.
If the area you live in has alcohol added to their unleaded gas, then you will probably need to rekit the carbuerator. Also check the spark arrestor for plugging up. Try to find a non alcohol, off road unleaded gas for your generator.
Jan 20, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
KM-450MAB making beaping noise-compressor will not run
The cleaning valve must be closed duing the ice making mode. If it is open, the machine will not make ice. The beeping you hear is the alarm which is present on the machine. Remove the front cover and read the included text. This will tell you what alarm you have.
Oct 07, 2008 | Hoshizaki Cubelet Ice MakerDispenser Water...
Model KM-450MAB--Ice Machine Making Beaping Noise
Keeps on beeping? Every 3 to 4 seconds? Try putting the thermostat wires together. An open bin thermostat will cause this problem and the board see it and starts beeping.
Drills Logo
133 people viewed this question
Top Panasonic Drills Experts
Craig Butler
Craig Butler
Joseph A Howard
Level 1 Expert
Are you a Panasonic Drill Expert? Answer questions, earn points and help others
