Question about HP ProCurve 2626 (J4900B) 24x10/100 Mbps Networking Switch
Default password i need to know the default password foor hp procurve 2626
  • 345 Answers
There is no default password on an HP switch. You can clear the password on a switch by powering on a switch and make sure it is done booting (you should see all the port light up for a short time in order down the switch when it is booted) then take a paper clip and press the clear button on the front of the switch. that will clear any password left on the switch
Posted on Nov 21, 2014
  • 14 Answers
SOURCE: Procurve 2626 installation
You'll need to obtain a comms lead - connects into the console port of the switch then into an RS232 port on your laptop. Then, you will be able to connect using hyper terminal and you can give the switch an IP address, username, etc. Even a hard-reset won't allow you to configure an IP address as by default it needs to be configured through the lead. Will they not talk without being configured? If you just hard reset them, they should just behave as unmanaged switches.
Posted on Oct 13, 2008
  • 25 Answers
SOURCE: HP procurve 2124 (j4868a) noisy fan
This switch has a lifetime warranty. Call HP and they will have a fan or new switch for you the following day.
Posted on Apr 14, 2010
  • 53 Answers
SOURCE: What is the default IP
check out the HP website. HP has a lot of very good resources for all of their products. here is the link:
http://www.hp.com/rnd/support/manuals/2650_6108.htm
hope I could help you out on this.
Posted on Oct 21, 2010
SOURCE: I want reset the factory
To reset using the CLI, run the command "erase startup-config". When prompted, say yes to reboot and that will restore the procurve switch back to factory settings after it starts up.
Posted on Mar 08, 2011
  • 378 Answers
SOURCE: Hi,this is pavan i want
What do you need it configured to support? Multiple subnets? VoIP support?
Here's an example to support 2 subnets, VLAN 1 Data and VLAN 2 Voice. This switch is the VLAN router for the site and it is also the default gateway for all the devices on the network.
show running-config
Running configuration:
; J4899A Configuration Editor; Created on release #H.10.50
hostname "HP 2650 dot 11 layer 3"
snmp-server contact "Your contact info here"
snmp-server location "Server Rack - Upper Switch"
time timezone -5
time daylight-time-rule Continental-US-and-Canada
interface 49
name "Uplink to HP2650 port 49 - 192.168.105.12"
flow-control
exit
interface 50
name "Uplink to HP2650 port 49 - 192.168.105.13"
flow-control
exit
ip routing
timesync sntp
snmp-server community "public" Unrestricted
vlan 1
name "Data"
untagged 1-46
ip address 192.168.105.11 255.255.255.0
ip helper-address 10.50.3.2
tagged 49-50
no untagged 47-48
exit
vlan 2
name "Voice"
untagged 47-48
ip address 10.50.3.11 255.255.255.0
tagged 1-46,49-50
exit
ip route 0.0.0.0 0.0.0.0 192.168.105.1
spanning-tree Always turn on Spanning Tree
spanning-tree priority 0 This switch is the master Spanning Tree operator.
password manager
password operator
Posted on Apr 25, 2011
Default password
HP ProCurve Switch 2600 Series Installation and Getting Started Guide
Page 1-9
ftp://ftp.hp.com/pub/networking/software/59908821-0904.pdf
Clear Button
This button is used for these purposes:
Deleting Passwords - When pressed by itself for at least one second, the button deletes any switch console access passwords that you may have configured. Use this feature if you have misplaced the password and need console access.
Jan 03, 2014 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
2626 default ip procurve
HP 2626 do not have a default IP address, you have to set the IP address on an enterprise class business switch. You can find the manual for your switch at http://www.hp.com
Dec 23, 2013 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Procurve 2626 default password
There is no default password. If a password is set you either need to know it or have physical access to the switch
Dec 19, 2013 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Default password for HP procurve j4899a
This link should tell you the answer. http://h30499.www3.hp.com/t5/Switches-Hubs-Modems-Legacy-ITRC/Clear-password-in-Procurve-2650/td-p/4598369#.U0sRNfldUok
Nov 01, 2012 | HP Hewlett Packard J4899B New ProCurve...
J9400b defult ip adress
There should be no default IP address on a 2626 switch. HP Procurve switches are setup by default to get an IP address by DHCP. To execute the factory default reset on the switch, perform these steps:
  1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
  2. Continue to press the Clear button while releasing the Reset button.
  3. When the Self Test LED begins to blink, release the Clear button. The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
Be aware, using these instructions will wipe out any configuration you have on the switch
Good Luck
Jan 21, 2012 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
What is the default IP for ProCurve 2626?
Oct 21, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Hi,this is pavan i want to b configure the HP procurve 2626 J4900B managed switch pls help me through anybody by giving the programme to configure it
show running-config
time timezone -5
interface 49
flow-control
exit
interface 50
flow-control
exit
ip routing
timesync sntp
vlan 1
name "Data"
untagged 1-46
tagged 49-50
no untagged 47-48
exit
vlan 2
name "Voice"
untagged 47-48
tagged 1-46,49-50
exit
password manager
password operator
Sep 20, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
I need the default password for ProCurve J4900B
There isn't one. If someone has added a password to the switch you can connect to it and at the prompt to enter the password, press the Clear button.
Sep 09, 2010 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Aug 14, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
HP ProCurve 2626 (J4900B) 24x10/100 Mbps Networking Switch Logo
480 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
