Question about De Dietrich Ovens
De Dietrich CX4844 fan element failure
I have a replacement part, but I can't see how to get in to replace it. Do I need to go in through the back? I'm also unable to find a repair manual on line. Any ideas?
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
  • 1462 Answers
SOURCE: Neff B1432 2002 Element blown
did you check the old element with a multimeter to make sure it is in fact faulty?
check continuity across the thermostat as well
Posted on Nov 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Posted on Nov 06, 2009
SOURCE: De Dietrich oven not working!
I suspect that it is the oven lock that needs replacing. I bought a De Deitrich oven (pyroclean) in Sept 2007. The oven failed to heat in Aug 2009. The oven lock needed replacing which meant the unit had to be removed from the wall. It was replaced under guarantee but failed again in June 2010 and was replaced at a cost of €140 by enginneer. I am very dissappoined in the oven and expected to have no problems with it considering the DeDeitrich name. I would not recommend it to a friend. By the way the clock is easy to use if you follow the instructions exactly. Oven used by two careful owners only.
Posted on Jun 30, 2010
barkencoa
  • 3463 Answers
SOURCE: my de dietrich oven is
If the fan is working o/k, then the oven element is most likely faulty.
This is located at the rear of the oven compartment behind a removeable cover.
Posted on Feb 28, 2011
Why does my Oven not heat up ?
Did you check to see if the element is receiving power? Is element open?
Feb 25, 2016 | De Dietrich Ovens
Should the element in a fan assisted oven oven glow red
When the fan is blowing steady across a heating element, it most likely won't allow it to get red hot
Mar 04, 2015 | De Dietrich Ovens
When on fan symbol only and with a temperature set manually, the oven will not heat. The bottom and top heating elements will heat up seperately on other settings
My oven is DOP705X. It had the same problem on two occasions. First time it was simply the fan element. Second time I thought it was the element so replaced it again, but no fix. Turns out it was the relay for the fan element, it had got sooty and black. A quick clean of the contacts with emery paper and it was all working again. If the relay needs replacing, a new one is £2.88 from RS Components, but replacing it will require a spot of skillful soldering.
Sep 29, 2014 | De Dietrich Ovens
Di dietrich 705x
usally just snap out or may have to remove a couple screws, see attached pics
Mar 22, 2013 | De Dietrich UMP404 Powerclean Stainless...
My de dietrich oven is not heating. the light and fan are ok
Feb 28, 2011 | De Dietrich Ovens
How to get the heating element out of the large oven in a De Dietrich DOD348*
If you mean the element at the back (not the bottom one), inside the oven undo a screw at the back to reveal the element, then undo one more screw attaching the element. THEN, totally disassemble the oven, removing all the cladding, taking off the top oven and controls, detaching lots of wires to be able to do this, in order to finally gain access to the 2 little nuts securing the element behind the oven. Then if you're not sufficiently dismayed by De Dietrich's design skills, email their customer service to be given the wrong part recommendation at twice the price of an independent supplier. Finally, buy part from independent supplier, spend several hours dismantling and rebuilding oven. Then it will work. But maybe don't ever buy De Dietrich (Brandt) again!
Dec 22, 2009 | De Dietrich Ovens
ELEMENT KEEPS BLOWING
The heater element should have 2 terminals , it does not matter which wire you put on the terminals, as they are both common,
If there is a third terminal, then that will be the earth terminal, which is usally located on the base of the element fixing bracket. so do not get the wires mixed up, because if you are putting the earth wire on the wrong terminal, it will blow.
Hope this helps you sort it out.
Dec 16, 2009 | De Dietrich Ovens
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
Mar 31, 2008 | Ovens
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
Ovens Logo
19 people viewed this question
Top De Dietrich Ovens Experts
ashburton
richie46
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
