Question about Epiphone John Lennon EJ160E Guitar Acoustic
Flat string sound
The second string when finger is apllied makes horrible sound as if there was a pick under it and plucked
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
There are two ways you can fix this,
A. You can get a fret job done.
B. you can buy a new neck.
and
C. You can get the action adjusted.
Posted on Mar 14, 2015
I have just bought a 1980 Hawk. But i am having trouble tuning it. it is also the pick-ups are really sensitive. It picks up every touch on the guitar. Putting your finger on a string sounds like a drum...
Your guitar Needs to be setup properly, tuning is tough need to wrap strings around tuner peg properly to stay in tune, and the pickups may need to be adjust farther away from the strings?
there are Tons of videos on YouTube showing basic guitar setup,
hope this helps?
Mar 05, 2015 | Music
Value of kimble grand serial 383273
this is a musical instrument to entertainment the people The first stringed instrument was the harp, on which the strings are plucked. The harmonic curve caused by the varied speaking lengths of strings dictated the shape of the frame of the piano and broadly follows the shape of a harp.
The monochord is simply a sound box with a single string stretched over a movable bridge to the position required, which is determined by a scale marked by "0" on the surface. The bridge is moved to each marking to give you a new note. It was plucked, and would now be referred to as a tone metre.
Mar 01, 2015 | Grand Music
How to operate an acoustic fender electric guitar Fishman tuner
If it's the same as mine, the tuner has a little clothespin clip. You clip that on to your guitar's headstock and turn it around till you can see the screen while picking strings. The tuner picks up vibrations through the headstock and with it's microphone and it tells you what it hears. The little needle tells you the note and if the string you're plucking is below that note, above that note or right on. You have to figure out if you're in the right octave on your own.
Dec 30, 2014 | Fender Music
Low e string has a funny noise when on rythm
you probably damaged the nut, check the distance between the low e string and the first fret after your tuned to standard. pluck low e string only if its buzzing on first fret you may either need new nut or a repair on the neck. if you have any questions feel free to ask
Jan 09, 2013 | Music
What is the proper way to change a string on a guitar so it doesn't slip?
The first thing to remember is that the strings will stretch so i always over tune it about a turn for small strings and 3 for the big strings. To prevent it from slipping when you are tightening the string pull it tight while turning it and make sure the string has overlapped its self a couple times before releasing it.
Apr 08, 2012 | Fender Music
I have no instructions. how do i use it? i want a detailed answer please.
Clamp it to the headstock of your guitar just like in the picture. Press the power button. Pluck one string on your guitar, the screen will light up with the corresponding note (standard tuning from largest string to smallest string is E A D G B E). The arrows will indicate whether the string is sharp or flat (too high or too low). More left arrows indicate that the string is too low, too many arrows on the left indicate that it is too high. Turn the tuning peg, slowly, on the corresponding string until you've got 6 solid arrows.
Here's a video
http://www.expotv.com/videos/reviews/16/154/IntellitouchPT1Tuner/275941
Dec 31, 2010 | IntelliTouch Communications Intellitouch...
Ibanez intonation problem
Hi there. Use guitar tuner. Pluck string in open position. Tune. Now pluck same string at 12th fret. If tuner says flat, adjust bridge for that string towards neck. Towards bridge if sharp. Repeat procedure until in tune at open and 12th fret. Go to next string and repeat procedure.
Thanks
Paul
May 11, 2009 | Music
No instructions for a yamaha erg 121 c electric guitar
i don't really know what instructions you expected, although you should have received something for the tuner and amp. I suspect that you are new to playing the guitar, as, I don't wish to sound disrespectful, you would know what to do! So first, and again I hope not to sound like I'm treating you like a dummy, plug the guitar into the tuner input. Or if It's a piezo tuner clamp it to your headstock. Most tuners are now automatic so it should pick up on the string you are striking.Repeatedly pluck the same string til the tuner changes colour, or flashes, or some other indication to tell you the string is at pitch. Repeat the above for all 6 strings.
Then plug the cable into the amp input, switch it on, and bugger about with the controls til you get a half decent sound. ( thats what the rest of us do).Don't expext too much from this package, it is budget level, but of quite good overall quality.hope this helps
Feb 05, 2009 | Yamaha Electric Guitar
Strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Nov 15, 2008 | Epiphone Aj-100 Acoustic Guitar
Epiphone John Lennon EJ160E Guitar Acoustic Logo
57 people viewed this question
Top Epiphone Music Experts
Robert Graf
Vito Vacirca Jr.
dave nyman
Level 1 Expert
Are you an Epiphone Music Expert? Answer questions, earn points and help others
