Question about Milwaukee 2690-24 18-Volt Hammer-Drill, Sawzall Reciprocating Saw, Circular Saw, and Worklight Combo Kit
How to change brushes
Cordless starting to cut out and loss power
My Makita DSS610 18v cordless circular saw stopped working mid cut. I changed the battery to another, fully charged, one but still nothing. Tried again next day, with both batteries, still nothing.
Hello Derek, it seems that your motor or motor brushes have failed please contact the manufacture about replacing the motor brushes.
Sep 15, 2016 | Makita Saws
How do i change the brushes on a 18V Makita BGA452 Grinder
With a little screwdriver you shall first remove the first dustcaps and then you see the brush holder caps which have to be removed with a suitable screwdriver thats by the most machines not hidden but however by this tool
Jun 28, 2015 | Makita Bga452 Lxt 18v Liion Cordless Angle...
SDS drill variable power
Ok about changing the brushes but have you searched if the place where the brushes are located allow the brushes to move forward freely or they are in a way were narrowed so that the brushes can only move for few millimeters?
Mar 06, 2014 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
My Makita cordless angle grinder (new, used once) BGA452 wont go, it starts then the overload light comes on and it stops? changed battery, still happens.
Obviously too late for you, but it may help others.
I had the same problem with a new Makita 18v lithium grinder and this worked.
Remove battery, remove brushes. Using good quality cotton buds, dip in Methalated spirit and insert into hole for brush down to armature, slowly rotate head of machine. Change cotton bud and repeat process, then clean the brush heads. Re-assemble and try. Note: Meths will dry completely leaving no residue, unlike turps etc.
Jul 16, 2011 | Makita Bga452 Lxt 18v Liion Cordless Angle...
Hello, I have a dewalt drill cordless 12V. I have taken the casing off and want to know how I want to know how I get to the brushes. It has stopped working and suspect that it is the brushes. I am not...
I fix cordless DeWalt drills every week!Look for two black carbon-like blocks found on either side of the commutator ( the central spindle ) they will each have one wire on the outside end attached to a spade connector so the brush can be easily removed by prying it out from beneath the spring holding the brush against the commutator.  Then the wire can be removed and the new brush installed.    Go online to http://www.toolpartsdirect.com and search for your model dewalt drill. they have an exploded diagram and parts listing for each model drill.  That will identify the brush for you if you have never seen one before.    If the drill was operating intermittently with lots of noise and usually blue sparks coming out, loss of power, increasing intermittant operation it would almost certainly benefit from replacing the brushes.   If it is simply dead, and was ever dropped.  check the battery terminals and the trigger mechanism.  Of course inspect the battery and check inside the drill for loose or broken wires and connections. I hope this is helpful. Good luck!
Dec 11, 2008 | Dewalt DC727KA 3/8" 12v Cordless...
Lose signal
While some loss is expected. You can change channels. 1-6-11 are the best for cutting signal loss because they do not overlap.. 2.4GHz device in operation, like a cordless phone or microwave oven can cause signal loss. Metal in walls, electrical devices and wires can also cause loss.
Jan 03, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Milwaukee 2690-24 18-Volt Hammer-Drill, Sawzall Reciprocating Saw, Circular Saw, and Worklight Combo Kit Logo
26 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
