Question about Acer Aspire 5742 Notebook
Micro sd 5742 - Acer Aspire 5742 Notebook
What Sd card do I need micro or standard and does any one do?
If it's a recent model, it is using micro SD. If you are not sure buy a micro with an SD Adapter. Most micro SD have them included in bloster
Now, your more serious problem is, if you don't even know if you are using a micro SD or an old dig SD, is what is memory size and speed you need.
SanDisk 32GB MicroSDHC High Speed Class 4 Card with MicroSD to SD Adapter
So, before buying any micro SD you should check the manual of your unspecified cell phone for it's specifications. If you buy an 8 GB micro SD and your cell phone is only compatible with 1 Gb, it won't recoize the new micro SD.
If you don't have a maunal do a google search for it, using terms
manual specifications, make and model of your cell phoen
Aug 18, 2015 | Cell Phones
Can i imput a sim card in an aspire 5742
in a word, no.
If you are trying to get photos from your phone, use a micro SD card. Your laptop should have a standard SD card readers, and with an adapter you can get the information off the Micro SD card.
Dec 07, 2011 | Acer Aspire 5742 Notebook
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card is locked how to unlock
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card get write protected help me to retrive it...
I hope this helps.
Aug 10, 2011 | Computers & Internet
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
Jan 04, 2010 | Kingston 2GB Secure Digital Memory Card
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
My phone NOKIA 6300 could not find micro SD card. please what do i do?
If it is a 4GB micro SD card it won't work, a nokia 6300 doesn't accept HC (high Capacity) micro SD cards. Maximum you can use is a 2 GB micro SD card.
Don't forget to rate, thks
Oct 28, 2008 | Samsung SGH-D900 Cellular Phone
Acer Aspire 5742 Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
