How to reconfigure a Telergy T503
How do i change the provider on this Telergy T503 IPTV box
How do I turn off closed captioning in HDMI? I've turned it off in tv mode but it still is on. It's annoying
What's the HDMI source? You need to disable the CC on the cable box or DVD player. These are only two of the possible HDMI sources that will provide the captions directly.
Without knowing the source, I can't tell you how to disable the captions. For many devices, you'll need to enter the settings. (Some cable/IPTV boxes will need a passcode to enter the settings menu.) On my IPTV box, the CC option is tucked into the Hardware Settings under Audio. On some satellite TV boxes, I found that the closed captioning had to be turned on at the primary box and that would enable secondary boxes to also show the captions. (It was an annoying feature for a family with one hard-of-hearing guest. They didn't need closed captions on the primary box. The specifics of their set-up and service meant that the secondary box couldn't display captions directly.)
Please add a comment with the HDMI source for specific information on turning off the captions that you currently see on that source device.
Nov 27, 2017 | Televison & Video
Where can we get info relating to IPTV server?
There are many websites on the internet which are offering information relating to a IPTV server. These are specially made for those people who are looking for quality information relating to a IPTV server.For more information please visit this website:https://www.speedyiptv.com/freeiptvlinks/
Aug 15, 2017 | Computers & Internet
Hi I have a Sony Bravia tv model KDL-55ex500 . I also have a mag 254 iptv box which will not load on this tv. Can you tell me how I can get this tv to accept this upload ?
hello how is it connected to the tv, through hdmi or scart one could be faulty try changing the cables over to another input or changing the cables, thanks
shaun
Feb 16, 2017 | Sony Televison & Video
How to connect tv to internet for netflix
First, I am assuming that you have the internet connected at your house and I am assuming that you have a wireless access point or a router with Ethernet connections on it. If you do not have these, then you cannot connect to the internet. On most smart TV's they have a "settings" or similarly named menu item, where you can connect to your home wireless system. Select this and then scroll down the menu until you fine something that says internet or wireless or even quick setup. From there you just select wireless, type in your access password and it should work. All this will be explained in the owners manual for your smart TV.
Feb 25, 2016 | Magnavox Televison & Video
Telergy T502
Input password. Try here for setup support: http://telergy.com/
Apr 24, 2013 | Computers & Internet
Failed association wireless connection
Did you reconfigure your router after you changed providers? Did you go from a phone company provider to a cable company provider or vice versa? If so they use different protocols and the router will need to be reconfigured. Phone companies such as AT&T use what is called PPOE and you have to put your Internet or Network userid and password into the router, you also will have to Bridge the router in most cases. Cable Companies use DHCP and there is no userid or password that has to go into the router.
Apr 04, 2012 | Dell Vostro 1000 Laptop
I have a Samsung LE40S8 tv. When connecting my
Do you have any further details on your Telergy Set Top Box, Model No. so I can look into this for you.
Jul 08, 2011 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
How do you reconfigure when you change network provider? Can this be done remotely?
Since the network provider is change you need to reconfigure it back by running the setup disc for it to detect and setup with the new configuration settings for it.But if you're not aware about those settings you can contact your provider to get the needed settings for it.
Apr 05, 2011 | NetGear RangeMax Next Wireless ADSL2+...
Computers & Internet Logo
261 people viewed this question
David Payne
David Payne
