Question about Surco S4050 S4050 Safari Rack 40 x 50 Cargo Rack Chevy Aveo 201
Load banging noise in the rear going over bumps
Just a load banging noise right rear going over any kind of bump
    Scholar:
    New Friend:
  • 59 Answers
Could be: (since I'm not familiar with your car/truck here's a couple things to look for/at.)
- Loose shock absorber
- Loose spring shackle
- Loose/broken spring
- Very worn wheel bearings (they'd have to be VERY bad though)
Of course, the above assumes you're pretty sure the noise is coming from he bottom of the vehicle?
Jack the vehicle up using stands. Put a bar under the tire while it's off the ground and lift the tire and see if you can see/hear what's making all the noise. Be careful doing this as the vehicle is jacked up. But if the wheel is loose enough, you should be able to see/hear where the noise is coming from.
Posted on Feb 09, 2015
While is my 2007 chevy uplander rear end so noisy?
Could be the exhaust system hitting the frame or body of vehicle when you hit a bump. There should be some wear marks where the pipe is hitting.
Aug 20, 2015 | 2007 Chevrolet Chevrolet Uplander
Why does it bump and bang out of balance?
I had a front loading washer (not Kenmore) that bumped, banged, and walked all over the floor. Called a service tech. The balancers are made of concrete and one of them was loose. Ended up making a mess as the balancer that was loose finally broke and we had chipped concrete dust everywhere. Not pretty!!! Ours was covered under warranty.
Jun 11, 2015 | Kenmore Washing Machines
Loud banging noise from rear end when going over bumps/dips in the road
look at your swayarm in rear see if its bent or bushings are gone also look at the choks see if one is broke
Aug 01, 2011 | 2000 Volkswagen Golf
How to access the rear shocks topside? banging noise going over small bumps, sounds like something may be loose.
HI,
Check the exhaust mounts first in the rear these maybe broken.
The tops of the shocks are accessed through the trunk area.
Thanks
Jason
Apr 18, 2011 | Cadillac CTS Cars & Trucks
Saab 93 - noisy when going over bumps on the road.
Have you tried driving over a bump whilst also applying the brakes? (Right foot on gas, left gently on brake - with no one behind you!) If the noise goes away, then it could be the brake pads that are not fitted correctly. Only posting this, as this just happened to mine...the mechanic took it over bumps and noise was there. Applied brakes whilst going over bump, noise went away. Replaced badly fitted rear pads (had been bodged by another garage) and the problem was solved.
Apr 23, 2009 | 2004 Saab 9-3
Noise in rear of 2003 Buick Century
i have the same problem. Some say it could be shocks, or the whole braking mechanism could be lose. I plan to fix it this week, and will post what i find out here.
Apr 22, 2009 | 2007 Buick Century
I think that the rear passenger sider shock absorber is broken. When I drive my car, it makes a metal banging noise, especially when I go over bumps. Is this really the problem? And if so, how much would...
it doesnt mean its the shock if its banging noise its probably just the top plate big differense $$$ top plate 40$ 1 hour labour hope its a fix and a fixya for me thank you pierre
Aug 08, 2008 | Pontiac Grand Am Cars & Trucks
Banging noise from rear of bmw 316 e36
It could be your subframe as well big problem with E36's. Also you can check your Rear Shock Mounts in the trunk by removing the carpet, they are under the speakers. Also check your brake pads, the little shim could have fallen off causing your brake pad to rattle over bumps. And check all your heat shields.
Jun 09, 2008 | 1997 BMW 318
Surco S4050 S4050 Safari Rack 40 x 50 Cargo Rack Chevy Aveo 201 Logo
1,025 people viewed this question
Top Surco Clothing Experts
treeeee
treeeee
shuyumeng
shuyumeng
Erin Wood
Erin Wood
Are you a Surco Clothing Expert? Answer questions, earn points and help others
