Question about New World G70m Gas Double Oven
NO POWER TO OVEN FUSE IN PLUG OK
I HAVE NO POWER TO OVEN OR GRILL CLOCK IS NOT LIGHTING UP FUSE OK
2 Suggested Answers
  • 1462 Answers
SOURCE: Clock
why did you have a new clock fitted and did you do it yourself? check at the clock to see if power present. if not, check the wiring loom to see if any breaks especially at any plugs and sockets. if you do not use the automatic function, you may want to bypass the clock
Posted on Mar 29, 2007
I have reset the clock the oven sounds as though it's working for just 2 seconds and then stops. The light will not come on at all. I have cleaned all contact points still no luck .
inverter failure blows safety fuse internally this will power down the oven to prevent further damage new inverter and fuse needed.
Feb 03, 2017 | Neff Ovens
Bottom oven stopped working. Clock display is totally blank but we have power to the oven as grill & top fan still coming on.
No make or model all pretty much the same oven power fed from clock/control either and open fuse feeding power to clock or bad clock have seen burnt wires going to clock
Apr 03, 2015 | Ovens
Using grill and everything tripped now grill or oven wont work
Electric grill most often uses heater element to heat up.Maybe your heater elemen is shorted to oven body thus tripping the safety device.
Check your grill system using insulation tester.If the insulation is low check the heater elemen insulation and if defective replace them.
Jun 17, 2012 | Zanussi ZBF360 Electric Single Oven
Candy Electric Oven no power in oven/grill at all, only clock
is the timer set, most ovens wont work if the timer is not set
Apr 07, 2010 | Neff U1421 Double circotherm Electric Oven
Neither the LED clock or the oven work today.
CHECK PLUG FUSE , AND SPUR FUSE IF THESE AR OK IT MAY BE YOU NEED TO REPLACE OVEN ELEMENT.
Oct 21, 2009 | Ovens
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
Dec 22, 2008 | Stoves 720EF Electric Double Oven
Turning on grill blows fuse on Electrolux EOG7330WN
get i an accredited electrician to check the grill element and fitting
there is a dead short in that area
Apr 23, 2017 | Electrolux EOG7330WN Gas Double Oven
Neff B1641 Switched my oven on the other night it made a noise like a fuse blowing and went dead no lights no controls whatsoever i checked the power and i traced it all the way to the control panel...
check you have power at the clock - the clock terminals not the relay. if not, there is a cut-out stat in the back. check this is still ok. if there is power at the clock then the clock itself may be faulty. you can bypass the clock by joining the terminals to the clock relay and get the oven going this way. another common source of problems is the terminal block where mains comes in and is distributed. these terminal blocks often burn out.
May 04, 2007 | Neff B1641 Single circotherm super...
New World G70m Gas Double Oven Logo
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
