Question about Okidata Oki C610N LED Printer - Color - 1200 x 600 dpi Print - Plain Paper Pri
OKI C610n error 980 resets - Okidata Oki C610N LED Printer - Color - 1200 x 600 dpi Print - Plain Paper Pri
Oki c710 error 980 reset
Per the technical manual - Media wrapped around the fuser error. Turn off the power. Replace the fuser....
It is possible to unravel the paper from the fuser.
Feb 15, 2014 | Oki Electric Industry OKI C710dn - - color...
Service call 984: fatal error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Mar 20, 2013 | Oki Brand Oki C610n Laser Printer...
How do I reset fatal error code 980 on a oki c5650
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
Jun 18, 2011 | OKI C5650n LED Laser Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Oki c 5600 980 fatal error
The error means that the media is wrapped around the heat roller of the fuser. The only way to reset this error is to replace the fuser unit.
Jul 20, 2009 | OKI C5500n Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
OKI C5500
Error 980 means media clinging to the fuser,remove the fuser and see if there is something wrong in it
Jul 07, 2008 | OKI C5500n Printer
Service call 980:Error
hola
quiem puede ayudarme a desifar el error 980 de ld oki c6100
gracias
Apr 09, 2008 | OKI Office Equipment & Supplies
980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
*Power OFF
Suggestion -
Apr 07, 2008 | OKI C5800Ldn Led Printer
Okidata Oki C610N LED Printer - Color - 1200 x 600 dpi Print - Plain Paper Pri Logo
18 people viewed this question
Top Okidata Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Okidata Office Equipment and Supply Expert? Answer questions, earn points and help others
