Question about Acer n310 Pocket PC
Acer pda 26 pin Connector,sync,charge,usb,socket,part
How do you replace the connector on the Acer n35?
4 Suggested Answers
SOURCE: Charging problem
try a hard reset
Posted on Dec 28, 2007
SOURCE: broken 22 Pin,sync,charge,connector
Here's a solution for the broken socket on Mio 168 and Medion Micromaxx mdppc150 clones. Cheers
Posted on Mar 29, 2008
SOURCE: Pin allocation in 26 pin connector?
try- John
Posted on Jun 03, 2009
  • 37 Answers
You guys need to reflash it using image, but Acer does not support this pda anymore... good news, I downloaded it before they removed it from webpage, so if you send me your email address and windows version, I will email you an image.
Posted on Jul 21, 2009
0 characters
1 Points
How can i open it and where to find the charger ?
  1. Connect the power cable to the jack on the sync cable adapter
  2. Connect the 26-pin device plug of the sync cable to the 26-pin connector to the bottom of the device.
  3. Connect the power plug to the grounded wall socket.
The LED indecator will start to flash green as soon as it begins to charge.
Jan 15, 2011 | ASUS Mypal A730W Windows Mobile 2003
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
try- John
Apr 09, 2009 | Acer n30 Pocket PC
No display
I removed the front cover and found that the touchscreen connector ribbon to the main board had come adrift. I reconnected it and hey presto I'm fully operational once again.
Dec 27, 2008 | Acer n35 Pocket PC
Can i Connect acer n35 to car lcd monitor
We can supply the LCD for GPS.
If you need it, feel free to contact with us.
Nov 26, 2008 | Acer n35 Pocket PC
Need driver for vista to sync my acer n35
Acer N35 is running on Windows Mobile 2003. You can use Windows Mobile Device Center 6.1 for windows Vista to sync your PDA to your computer. You can Download Windows mobile device center 6.1 on this link :
After installing, plug in the Acer N35 PDA and Windows Mobile Center will; automatically start and you can transfer files and sync contacts etc.
Oct 27, 2008 | PDAs
Acer n35
some firewalls, like zone-alarm can cause problems with active sync.
maybe you should try it once with a deactivated firewall,
or change your firewall settings, so that the following ports are available:
• 990 (RAPI) • 999 (Status) • 5721 (DTPT) • 5678 (Legacy Replication) • 5679 (Handshake & Legacy Replication) • 26675 (Airsync)
Apr 01, 2008 | Acer n35 Pocket PC
Broken 22 Pin,sync,charge,connector
Mar 17, 2008 | Mitac Mio 168 Pocket PC
Charging problem
try a hard reset
Dec 21, 2007 | Acer n35 Pocket PC
RE: HP Ipaq H6315
igot demage body as well as charging socket
how do iget it in india
Oct 26, 2007 | HP iPAQ h6315 Smartphone
Acer n310 Pocket PC Logo
750 people viewed this question
Top Acer PDAs Experts
Are you an Acer PDA Expert? Answer questions, earn points and help others
